FE block inquiry
Old Jun 16, 2021 | 09:05 AM
Restenhaus72's Avatar
Restenhaus72
FE block inquiry
Checking to see if FE blocks with the "mirror 105" stamping had solely the 390 rotating assembly in them from the factory. Thanks !
Old Jun 16, 2021 | 09:09 AM
Flecker's Avatar
Flecker
Nope... my 360 had the 105 casting mark on it too.
Old Jun 16, 2021 | 10:02 AM
440 sixpack's Avatar
440 sixpack
Measure the stroke .
Old Jun 16, 2021 | 12:45 PM
matthewq4b's Avatar
matthewq4b
The 390 and the 360 used the same castings. As noted the only way to tell is to check the stroke.
Old Jun 16, 2021 | 04:49 PM
flowney's Avatar
flowney
Some have claimed the mirror 105 block is marginally stronger than the blocks with un-mirrored 352 markings. I have a mirror 105 block that came from the factory as a 360 in a 1976 F-100. As I recall, the bottom end webbing looked to be a little more robust. Prolly not significant.
78fordranger
Dec 6, 2008 07:44 PM
jj22ee
Mar 11, 2006 10:39 AM
DustinDLamb
Aug 30, 2005 11:10 PM
swampo
Jul 4, 2004 12:54 PM
freejay
May 20, 2003 10:10 AM
