390 Engine
Old Aug 30, 2005 | 01:36 PM
DustinDLamb's Avatar
DustinDLamb
390 Engine
What is the max bore on a 390 FE Block?
Old Aug 30, 2005 | 01:47 PM
fordeverpower's Avatar
fordeverpower
.060-.080 with .080 pending sonic testing.
Old Aug 30, 2005 | 02:52 PM
rusty70f100's Avatar
rusty70f100
It kind of depends on which FE block you get. Some, like the FT and the mirror 105 type blocks, will take a bigger overbore than standard 390 blocks. The mirror 105 blocks are usually found as later (1970's) 360 engines, in pickup trucks. In any case, with any overbore over .060", have it sonic checked.
We get a lot of people on here wanting to build a maximum cubic inch FE. I can appreciate that, but overboring is not the way to do it. You get minimal gains and take a lot of life out of a perfectly good block. Overboring should be reserved to cleaning up cylinder walls. If you want cubic inches, switch to a bigger crank.
Old Aug 30, 2005 | 03:25 PM
fordeverpower
Right on, build a stroker for more cubes.
Old Aug 30, 2005 | 11:10 PM
biz4two's Avatar
biz4two
Arrow
Here is some really "GOOD" reading on our FE's...your question is #4.
http://www.clubfte.com/users/ratsmoker/FAQ.html
