Soooo was driving (2005 Excursion 6.0) along the interstate and I use my DASHDAQ for PID info. All was well but as I was almost at my destination I decided to check for codes. My normal glow plug 2 circuit code was the only thing that showed up. Sweet! Cleared it and went back to the gauges screen…and the only gauges that showed any values were coolant temp, trans temp, and battery voltage. EGT still showed but that’s not through the OBD port. No oil temp, no boost, FICM sync, crank sync, FICM power, anything else. Just blank on those PID’s. I’m guessing I blew a fuse somehow? But the DASHDAQ still powers up so I’m confused. The fuel gauge still works in the instrument cluster, so…I dunno 😊
Oh, also now the glow plug circuit 2 code isn’t showing up, so it’s not reading codes either
