rust spot on tone ring
Old Jun 12, 2021 | 12:34 PM
Sti470's Avatar
Sti470
4wd Low
94 cc xlt srw idi turbo 4x4
My speedometer bounces about 3 mph at higher speeds. Cruise control functions but is constantly adjusting quickly. Once in a while the OD light will flash and gives harsh shifts. I replaced the VSS sensor on the differential, no change. Looking at the tone ring, there is no damage except there are 2 teeth next to each other that have rust on them and another one by itself with rust. It is not a rust that I can just scratch off with a finger nail. Is this system so sensitive that this may be causing my problem? I don't have a scope to use.
Old Jun 13, 2021 | 01:53 AM
Prototypemech's Avatar
Prototypemech
check the tcu for codes and see why its unhappy. Thatll lead you to the right path.
Old Jun 14, 2021 | 08:50 PM
Sti470's Avatar
Sti470
4wd Low
I did the code test. KOEO with the gas pedal fully depressed I got 5 spaced out 1's and code 29
with the gas pedal not depressed I got codes 23 and 29 with no 1's at the beginning.
If I am understanding what others have said, the 23 without pedal being depressed doesn't matter.
The 29 is the vehicle speed sensor. Which, brings me back to my original question. Can the rust spots cause this? When I replaced the VSS nothing seemed to change. Even the bouncing of the speedometer stayed the same. I'm thinking to trace the wiring before doing anything else. I did replace it with one from Autozone. Does this matter?
flowney
26
Mar 4, 2019 03:00 AM
Greywolf
Projects
Jul 10, 2012 12:32 PM
tommy70084
Mar 19, 2009 06:45 PM
vettman
Paint & Bodywork
Mar 17, 2008 10:07 PM
Powerstroke baby
Paint & Bodywork
Sep 28, 2003 03:46 PM
