Rust
Old Mar 11, 2009 | 06:47 PM
tommy70084's Avatar
tommy70084
Rust
Does anybody know of some real real good rust killer.I'm tring to kill the rust on my fram(it's not real bad).I dont won't to have to take it and get it blasted
Old Mar 11, 2009 | 06:57 PM
Sooper-Doodie's Avatar
Sooper-Doodie
The rustoleum "rust reformer" works well. It turns rust to primer. I then just pained over it.
Old Mar 11, 2009 | 08:27 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I've used "Ospho" and similar Phosphoric acid rust treatments before.
"Rust Mort" also works well for me.
Old Mar 11, 2009 | 10:29 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Bull frog Products "Bull Frog Rustorer" does a fine job.
Rust-Blok is another I've used, prefer Bull Frog.
-Enjoy
fh : )_~
Old Mar 12, 2009 | 02:07 PM
white rose's Avatar
white rose
Ospho, let it set for 24 hrs and paint over it. Works great.
Old Mar 13, 2009 | 05:00 PM
kickingber's Avatar
kickingber
p.o.r.15 (Paint over rust) I used it on my frame and it seemed to do a good job. It will look grate when first painted,but if you leave in in direct sunlight it will turn a gray/white, so you have to paint over it once it is dry.
Old Mar 18, 2009 | 01:20 PM
bobzdar's Avatar
bobzdar
2nd POR-15 and Rustoleum, I've used both with good results. The rustoleum is easier to use but not at durable as POR-15 (and the hammered metal finish looks really cool). POR is the toughest stuff I've ever encountered, but it's a real PITA to use. If you want quick and easy and reasonably durable, I'd use a wire brush to get any loose flaky rust off and then spray bomb it with rustoleum.
Old Mar 18, 2009 | 05:00 PM
Redneck1465's Avatar
Redneck1465
Personnally if you want to do it right I would sand it down and then use something like por 15 then paint it then use an undercoat spray. Thats what I did.
Old Mar 18, 2009 | 10:42 PM
bobzdar's Avatar
bobzdar
Make sure you don't sand the rust off or the por won't stick - it bonds with the rust, if you sand it all off you need to then either let it rust over or treat the surface with another product before putting the POR on. The best way to apply it is to remove loose rust and grime and then apply to the rusted area.
Old Mar 19, 2009 | 10:43 AM
Redneck1465
Thats what I mean you probably arent going to take the time to sand it down to bare metal with a peice of sand paper and your hand...
Old Mar 19, 2009 | 03:18 PM
tommy70084's Avatar
tommy70084
Thanks Guys that helps alot
Old Mar 19, 2009 | 06:45 PM
emgee's Avatar
emgee
For what it's worth, here's a link to product that's supposedly better in terms of finish than POR 15.
Paint Over Rust to Stop Rust Permanently With Chassis Saver Truck & Auto Underbody Coating
choate
Jan 9, 2015 04:31 PM
X36
Paint & Bodywork
Jan 29, 2008 03:08 AM
jake00
16
May 15, 2007 07:56 PM
fordinmudd
Appearance & Dress-Up
Nov 12, 2006 01:23 PM
MemOrex
Paint & Bodywork
Dec 8, 2004 10:47 PM
