Air conditioner
Old May 28, 2022 | 04:08 PM
marksman76's Avatar
marksman76
I called my local Ford parts friend today.
They are open.
He said his drawing shows a nut.
I know it's a bolt because I have modified my air gap before.
I drove there with my clutch part, and found a bolt that is close, but it is not really what I need.
The part number i purchased today, and have yet to install is W503924 S439 bolt STD09
So I am still seeking help with actual part number, if anybody can help??
Thank you!!
Old May 28, 2022 | 04:38 PM
Walleye Hunter's Avatar
Walleye Hunter
Close but no cigar in what way? I get most of my bolts at my local ACE, they have an incredible selection of nut, bolts, springs, clips, etc. And they have an apparatus set up that I can insert bolt and determine its size and thread count.
Old May 28, 2022 | 04:44 PM
marksman76's Avatar
marksman76
The factory bolt I am missing has the forged on flange washer aka flanged head bolt. ( Thank you FordTruckNoob! )
The one I bought today has a smaller diameter washer than the flange.
The new bolt's washer is rotatable but not removable. Which is ok, but it is not welded solid.
Old May 28, 2022 | 05:05 PM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by marksman76
The factory bolt I am missing has the forged on flange washer.
That’s called a flanged head bolt as mentioned in post #15.
Old May 28, 2022 | 05:44 PM
Walleye Hunter
And I'd bet my valuables that ACE would have one.
Old Jun 23, 2023 | 05:20 AM
Kbs117's Avatar
Kbs117
Originally Posted by LAMADMAN
Hey guys, it's been a while. I'm having a weird ac problem. My ac works fine at low speeds,45 and under. When I get up to highway speed it will go warm. I put some coolant in and the gauge reads good. Y'all think the clutch is going out? High pressure switch? This is the first time in ten years it has acted up. Input appreciated.
it can be several things. The first thing is to be sure the fan clutch and air flow through the radiator is good. Next thing, replace both high and low pressure switches, one of them is bad and shutting the system down at higher rpms. Put a set of gauges on it, run them up and lay them on the windshield and drive it until the problem occurs. Have someone video what the gauges are doing when it stops cooling. My bet is its under charged due to low airflow at low speeds, and then when you get up some speed and cool it off, the low and high pressure drops and the low pressure switch kills the compressor. Fixed a hundred doing that.. blow the radiator, air to air, and condenser out by taking them off the truck. Trust me, they are full of crap.. As for the fan clutch. Take a roll of papertowels and while idling at a normal temperature, if you can apply gentle pressure to the fan blade for 20 seconds, and stop it, the clutch is bad.. this also applies to the electric clutches on the 6.0 diesel. But you want to unplug the clutch before doing this test.. good luck..
Superm1952
Jun 24, 2023 07:10 AM
rkmaxwel
Jul 11, 2013 10:22 PM
Baatzy
30
May 14, 2013 05:50 AM
VA250SD
Aug 9, 2011 12:08 PM
GMAESTRI
1997 - 2003 F150
May 22, 2010 08:41 AM
