You have to match to axle type which depends on drive type, i.e., 2WD vs 4WD.
2X4 = Twin-I Beam
4X4 = Monotube
thanks. Moog lists two for 00-04. Than they have two more parts numbers for 05-10. I was thinking moog listed the 05-10 for the different steering gear on the 05-10 f250 and just lumped the 05 excursion in.
05+ F250 has a larger sector shaft so it uses a diffrent pitman arm.
05 excursion uses the same steer gear as the 00-04 excursions since they didnt switch to the coil/link front suspension, basically 05+ f250 changed the whole front steering and suspension and excursions stayed the same.
thanks Pirate. So I should order the 04 pitman for monobeam? (My ex is 4x4)
yes if that is how they list it. some places list by spline count. yours should be 36 ( physically count your sector shaft to verify as I am getting old and senile )
