Upcoming Project / Rust HELP!
Old Jun 10, 2021 | 11:59 PM
jgoebel88's Avatar
jgoebel88
So I am going to undertake the big project of changing leaf springs (thanks Junior at ATS), shocks (KYB Monomax) and adding RAS this weekend (Yes, I plan on posting a write-up on here when its done). I want to take care of any surface rust I find throughout the process, but don't know the best product to use. My first thought is using Rust Reformer, then painting over it.
My biggest question is, what do I use to paint over the Rust Reformer? I was debating between Rubberized Undercoat (nervous about trapping moisture...), truck bed liner spray (don't want to change clearances with the added thickness), and just regular undercoating spray. Any recommendations?
Old Jun 11, 2021 | 06:36 AM
Dweber85rc's Avatar
Dweber85rc
I would not recommend undercoating of any kind unless you are going to do yearly touchups. Ideally you want a rust encapsulator, like eastwood rust encapsulator platinum.
Old Jun 11, 2021 | 08:37 AM
jgoebel88's Avatar
jgoebel88
That is what I was understanding as well. Do you paint over the encapsulator? Most of them are described as "primers". If you do paint over, what do you use?
Old Jun 11, 2021 | 09:31 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Originally Posted by jgoebel88
So I am going to undertake the big project of changing leaf springs (thanks Junior at ATS), shocks (KYB Monomax) and adding RAS this weekend (Yes, I plan on posting a write-up on here when its done). ?
if you are buying new springs why are you also using a "add a leaf" or in the case of the RAS a add a coil ?
why not just have install a leaf spring with the spring rate you want from the get go ?
Dweber85rc's Avatar
Dweber85rc
Underneath the vehicle I used eastwood chassis saver paint and that went on with no issues or prep after putting rust encapsulator on. On body panels, I had to use an automotive primer to go over it or I had issues with the duplicolor rattle can paint I was using not wanting to stick to the rust encapsulator, I could rub it off after it dried and you never knew it was there! It's possible I was applying it incorrectly also, I am not sure I've attained amateur status yet
Old Jun 11, 2021 | 09:40 AM
Smoothwater's Avatar
Smoothwater
Used Eastwood Rust Encapsulator in matte black on the frame and gas tank skid plate. Came out nice. Didn't top coat yet.
Old Jun 11, 2021 | 09:50 AM
carbon coupe's Avatar
carbon coupe
A painter I used to deal with would take a frame to a powder coater, then DA the whole thing. The powder coat would fill all the rust pits and he would just smooth it and paint it. Looked new. Neat trick.
I have a tank tub at the powder coater right now. Anxious to get it back.
Old Jun 11, 2021 | 09:59 AM
pirate4x4_camo
the answer to your question really depends on the extent of the rust and to what level you are wanting the underbody of your Excursion protected.
regardless of any paint companies marketing painting over rust is a bad idea for long term duribility.
my .02 would be use a wire wheel to get to bare metal, us a self etching primer on the clean metal, paint satin black, that will seal the metal and prevent it from rusting. to keep the paint from chipping use a ruberized coating then a finish coat of satin black to make it look nice.
if not rusty than ruberized coating, which usually dries to a weird brownish color so I prefer to finish paint it satin black.
for simple rattle can jobs Rustolem brand is a great product.
Old Jun 11, 2021 | 10:38 AM
jgoebel88's Avatar
jgoebel88
no real reason. I ordered the V code front and C code rear. I tow a 9,000lb travel trailer most of the time and thought the RAS would add to the stability and make towing an even better experience than it already is. It may be overkill, but hey, what’s the point in having an Ex if you don’t like overkill
Old Jun 11, 2021 | 10:42 AM
jgoebel88's Avatar
jgoebel88
I will wire wheel/wire brush as much as I can. This year my Ex project is the suspension and I wanted to hit individual parts as I have them removed. Next year is penciled in for full rust repair.
Old Jun 11, 2021 | 10:43 AM
jgoebel88's Avatar
jgoebel88
this would be ideal. I’ll look into it when I start tackling more rust issues.
Old Jun 11, 2021 | 10:44 AM
jgoebel88's Avatar
jgoebel88
I am about to find out what my status is this weekend, but I think I will be below amateur as well haha. Thanks for the reply, this is what I was looking for.
Old Jun 11, 2021 | 12:25 PM
pirate4x4_camo
my point would be to install a suspension that works better than stock for not just towing but ride quality and handeling.
anyhow, its no so much your design is overkill but seems pointless to use a dual rate leaf spring that collapses onto the secondary spring at curb weight.effectively making it a single rate spring and then on top of that add another spring. seems like a lot of misguided effort to end up with a inferior suspension.
me thinks a single rate main pack with a spring rate suited for your unlaiden weight and desired ride height and than use an air spring which is adjustable to match any payload such as towing.
mount the spring directly to the perch and ditching the block will effectivly deal with any spring wrap concerns.
the part many people over look when just heaping on a bunch of springs is the spring rate is so high you will never find a shock to work,that means your ride quality and handeling is always going to suck.
follow the suspension design principle of " use the lowest spring rate possible" and it will yield you a much better outcome.
Old Jun 11, 2021 | 05:37 PM
jgoebel88's Avatar
jgoebel88
Ya that makes sense. I guess I was thinking about it like I am putting stock F350 leafs (or close to it) on and adding RAS. So, essentially like adding RAS to a stock F350. I definitely went back and forth between RAS and airbags for a while.
I will let you know how it works out, but definitely anything will be better than what I have now (which does almost nothing ha).
Thanks for your input!
Robscoe
Apr 30, 2021 10:54 AM
Meridian_Mike
64
May 1, 2019 06:34 AM
madscientist
Jul 29, 2015 01:25 AM
Bigdaddy29384
15
Mar 17, 2005 06:44 PM
ralph_the_tech
Aug 14, 2003 05:11 PM
