351W Timing Problem Resolved
Old Jun 9, 2021 | 06:29 PM
Prionus's Avatar
Prionus
Thanks for the help with my 1982 F350 timing issue (351W). The marks were very high with the timing light and I realized that the idle was set too high, so the distributor weights were advancing the timing. I turned the idle way down and set the timing with the light AND vacuum gauge. The mark was dead on 10 degrees BTDC and the vacuum was 20 mmHg. It still stumbles a bit at idle, but the throttle is snappy. I will get new a rotor, cap, and plugs, and try adjusting the carb with the vacuum gauge.
john jamieson
17
Oct 12, 2015 11:32 PM
bra$$monkey
Jan 31, 2014 09:29 PM
nlareau
Aug 26, 2011 08:10 AM
cjben
Mar 22, 2005 06:18 PM
bigbore
1978 - 1996 Big Bronco
Mar 4, 2004 11:44 AM
