Tune-up by vacuum method
Thanks. john
Usually a V8 will run best with around 34 to 38 degrees of "total timing" which, despite the name is not counting the vacuum advance, this usually adds another 10 to 15 degrees when engine load is light, and vacuum is high.
Now, we can divide that 36 degrees say, however we want between crank timing, and mechanical timing, but we always want about 34 to 38 total. Too much initial usually causes starter kickback, especially when warm, though. Engine manufacturers usually have a pretty low initial crank timing - 4 to 8 degrees say - and then a whole bunch of too much mechanical advance - and, adding insult to injury, comes in very late, or at a high RPM, close to 4000 RPM or even more. If you're routinely hauling gravel and using the truck as a truck, that's probably what you want. If not, not.
What I'm getting at with all this though, is be careful. Advancing the crank timing, without decreasing the mechanical advance, usually doesn't work so well, there isn't "room" so to speak, especially with a high compression motor. Best results by curving the distributor. May need to use premium fuel for maximum performance. By installing lighter spring(s) in the distributor, and limiting the amount of mechanical advance versus crank advance, we bring in a little more initial timing, a little less mechanical, but earlier in RPM say 2800 RPM. This makes for a lot better performance and acceleration.
Here's how to set the basic ignition timing with a gauge if you want to experiment with that. Disconnect and plug vacuum advance. Connect gauge to a source of manifold (constant) vacuum. At book idle spec, advance distributor timing clockwise. The idle RPM will increase along with the indicated vacuum. A normal, healthy stock V8 will pull a maximum of around 19" or 20" at sea level. This may be too much advance, though.
As you continue advancing clockwise the idle will at some point stop increasing, and start to hunt or stumble and wander. The engine vacuum will start to drop off. Retard the timing back, about 1" from the maximum smooth idle point that is (before it starts to break up), usually around 18" something like that. In Tucson it may end up maybe a little lower, because of the altitude. Take for a short test drive. Check for pinging on full throttle acceleration. Back off a little if pinging or knock is evident. Reconnect vacuum advance. Check for engine knock or pinging during part throttle acceleration at cruise and, at steady highway cruise. A very light occasional knock on part throttle acceleration is OK.
When you get a chance, verify the timing with a light. Very likely you will find this vacuum timed engine "sweet spot" is around 12 degrees or so. Again - severe pinging may result if the distributor is not adjusted to allow for this. Excessive advance may break a piston ring or a hole in the piston itself. But, a vacuum gauge will allow one to adjust their engine and carb to a high state of tune. They are a great diagnostic tool as well. Let us know what you find.
I'll help, but we need more information. Do you have a good timing light and marks? How far into this do you want to get? Do you just want to loosen and turn the distributor or more? Is this a stock engine, what are you goals, etc.
I need to modify one thing about what Tedster9 said.
The first thing that needs to be done here is to put a timing light on it and take note of the timing. The timing & idle will also likely be unstable to get a good measurement. Adjust the carb to slow idle and readjust timing to max vacuum. Then take note of the timing, I call this number 'ideal idle timing'
Next shut it off and try and start it again. It's likely that the timing will be too advanced to start, that it will kick back. Retard the timing and try again until it starts easily. Re-adjust carb and note timing, I call this 'Ideal starting timing'
There's more but at this point it's safe to ......
It's a good plan to readjust idle mixture on the carb too, anytime the timing is changed. Using a gauge is a good training exercise, if people can just learn to put the timing light away for a while.
Find where the engine runs best and don't worry too much about what it ends up at. The Y block in my truck seems to run best somewhere around 12 to 14 degrees. No starter kickback, idles smooth, runs good. The distributor has limited mechanical advance as described though, total is still around 34 degrees. This is where a timing light is really required - seeing how much total timing there is. and when the advance comes in RPM wise.
Some timing tape helps to see what's what for this.
Biggest factors are if I have any reason to trust the accuracy of the marks and if I can hear a ping over the exhaust.
However number wise A LOT can be done with a piston stop, timing tape, and a plain back to zero timing light.
This one is Craftsman but they were sold under many names with the only difference being the sticker on the side. Back to zero versions have a dial on the back that delays the flash a # of degrees. Well made tough simple suckers. I'm 99% there's no new ones you have to find them used.
You need to find out if your balancer has slipped. For this you'll need a piston stop and a tailors measuring tape. Piston stop tool will look like this
It goes in the spark plug hole to stop the piston. You install it, turn the engine by hand in one direction till it stops, mark the balancer, turn the other direction till is stops, mark the balancer. Then use the tailors tape to find the point exactly in between the marks, that will be TDC.
I personally dislike Autolite 2100/4100 carbs, I'd replace it with a 4bbl manifold and a Holley based carb. I'm also guessing you still have points. If you really want to tune just get at the very least a DSII setup and you'll need an adjustable vacuum advance. IMO MSD distributors are very worth the money, consider it.
I really appriciate every ones input. It's been 30 plus years since I've done an old fashioned tune up and I'm reeducating myself on the subject.
My 410 and 390 are both at 10*.
If you would like to make the ° symbol when typing, you can use these methods:
- On PCs - hold down the Alt key and on the numeric keypad on the right of the keyboard, type 0176, or Alt+ 248 When you release the Alt Key, a ° should be there.
- On Macs - option shift 8.
Thanks! you always have those little tidbits that are handy!
