Engine search
Old Jun 8, 2021 | 07:59 PM
Harley6's Avatar
Harley6
Engine search
So far I’m striking out in my search for a 302 or 351w engine to replace the 240 in the 1966 F100 I’m rebuilding.
I would prefer an engine/automatic transmission that’s ready to drop in and run. I had been told these were plentiful, but salvage yards I’ve called say they don’t have anything that will fit. My understanding is any 302 or 351w between 1965 and 1979 should fit.
Any suggestion is greatly appreciated. I’m a raw rookie at this.
Old Jun 9, 2021 | 12:09 AM
Order and Chaos's Avatar
Order and Chaos
I believe up to end of the production year 1964 the Windsor V-8 (260 or 289) should be a 5 bolt bellhousing pattern. Early1965'ish-1993 289/302/351w should all be the same transmission bellhousing 6 bolt pattern, In the late 80's they started calling the 302 a 5.0 and it picked up roller cam/lifters. Plenty of 302/5.0 liter powered everything across the ford model lineup.
Old Jun 9, 2021 | 04:53 AM
Crop Duster's Avatar
Crop Duster
What you are asking for is not going to be a bolt it in and drive away deal unless you find a complete donor truck up to a 79.
The 302/351W carbureted engines are plentiful but they are all over 30 years old.
You can accomplish what you want with some hotrod engineering and a donor car or truck up to the mid 80's. If you go the donor route make sure it is running and driving. You won't find one of those in a junk yard.
Going from a standard trans to an auto means a lot of stars have to line up for it to work. IE. shift linkage, kickdown linkage, what manual lever is in the transmission, LWB or SWB, whole different drive shaft set up, what type of neutral safety etc.
You can do it, good luck.
MavSprint
Sep 24, 2013 10:08 PM
MavSprint
Aug 30, 2013 09:41 AM
54TexasF100
15
Jul 26, 2011 08:11 AM
Garland
21
Sep 2, 2004 05:02 AM
