Steering help needed!
Old Jun 7, 2021 | 09:14 PM
08f1505.4's Avatar
08f1505.4
Please help! I have an issue with the steering on my 08 f150. I was backing up over a bump and heard a popping sound. Now I have limited power steering. Wheel will turn left with some slight binding but have no power to the right. I have checked the shaft between the steering wheel and rack as well as any visible ball joints. I also tested the pump at high rpm with no improvement. No fluid has leaked out. I’m thinking it could be the rack. Any ideas of anything else to check out? Thanks in advance.
Old Jun 8, 2021 | 12:48 PM
Beechkid's Avatar
Beechkid
In short, yes, the rack is damaged internally................ IMHO swag thoughts
Old Jun 8, 2021 | 01:03 PM
ford390gashog's Avatar
ford390gashog
Replace the rack, the spool valve has failed.
Old Jun 8, 2021 | 04:50 PM
08f1505.4's Avatar
08f1505.4
Thanks
Thanks for the replies I was thinking rack but wanted some other thoughts. Don’t like throwing parts at it unless I’m relatively sure.
Liquid10Rider
32
Jun 14, 2015 08:30 PM
Xcelor8
Feb 6, 2015 12:34 PM
JMyers0901
Feb 25, 2013 05:27 PM
A H DEVELOPMENT
Jan 25, 2010 07:09 PM
PSUJTF76
2004 - 2008 F150
Aug 14, 2009 01:07 PM
