Ford transmission question
Old Sep 3, 2000 | 08:16 AM
mthome's Avatar
mthome
I need a transmission for a 1991 Ford 1/2 ton automatic with overdrive built in the shifter linkage. I found a trans in another truck that is a 1990 Ford 1/2 ton automatic same engine but the overdrive is a button on the dash....does anyone know if this transmission will fit in my 1991?
Old Sep 4, 2000 | 07:10 AM
dinosaurfan's Avatar
dinosaurfan
Probably it will fit, the reason that some trucks have a button is to turn the overdrive off, some guys don't want it when they are towing or 4 wheeling. If the truck you found has the right bell housing pattern you could add the button to yours or just forget it,we have the button but never use it. what does you mechanic think? DF
Old Sep 4, 2000 | 07:26 PM
fjones's Avatar
fjones
wildcat99
15
Apr 3, 2012 09:34 AM
Papa Ford
Sep 7, 2011 12:07 PM
dieterschmied
Apr 18, 2011 10:20 PM
fordflaresides
General Automotive Discussion
Jan 9, 2006 12:10 AM
Mr Mopar
Bronco II
Sep 10, 2004 09:11 PM
