Sponsored by: Real Truck
Trans trouble
Old Jun 1, 2021 | 06:28 PM
conor98's Avatar
conor98
Trans trouble
Hey folks I’ve got a 2002 f-250 with the 7.3. I recently picked this truck up, and I’ve had nothing but problems with the trans. For whatever reason it doesn’t want to accept 2nd gear. It will ride the rpm up to almost 3k till it shifts down to third. I recently pulled the tuner chip that had been installed, no change. Should I be looking at a mechanical issue or electrical? And what could cause that failure?
Old Jun 1, 2021 | 06:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There should be codes stored in the PCM to help diagnose what's wrong. You need those.
To read the codes I recommend Forscan. You can download it free at www.forscan.org. Their webpage tells how to select an adapter to plug into the OBDII port. I bought mine from Amazon for less than $30.
Or you could take it to a good independent shop or a Ford dealer to read the codes. The places that read codes free CANNOT read these codes.
Goose52
13
Nov 19, 2020 07:19 AM
brian.b
Feb 23, 2019 02:42 PM
Northern-1
Dec 11, 2017 07:48 AM
05 powerstroke
Jul 15, 2015 09:47 AM
No-powerstroke
Jun 9, 2004 11:19 PM
