wiring help
Old May 30, 2021 | 09:56 PM
77ford250's Avatar
77ford250
wiring help
I have a 1977 F250 Custom im needing help on where Im supposed to locate grounding straps on the truck and where does my negative battery cable goes as well? correct me if im wrong but I believe I need a grounding strap on the engine to body and then another one on body to frame but I could be completely wrong
thank you
Old May 30, 2021 | 11:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Neg battery to eng block in the alternator area. Intake manifold to firewall (dvrs side). And this is ok to add too.
Old May 31, 2021 | 12:56 AM
Flecker's Avatar
Flecker
^ THIS! I added a ground like the above pic to the radiator core support. The headlights and parking lights on the grill have a ground strap that connects there.
Also, Question for 77... Where'd ya get that battery hold down bracket? Is that the og or an aftermarket? I need one for mine.
Old May 31, 2021 | 07:48 AM
77&79F250's Avatar
77&79F250
If you are asking me, that is just a FTE pic I saved for a great example. But that hold down strap is common to a lot of JY vehicles I see. It is for a specific size of battery though. I had one at one time, but it would not fit my battery, so I had to grind off the 90* edges.
Old May 31, 2021 | 08:17 AM
mudbogger2's Avatar
mudbogger2
Main battery ground wire to engine block. At that same connection on the block run a ground strap to the frame. Secondary smaller negative lead to radiator support. Also a frame to cab ground strap. This is how I have mine set up.
You can find those at most every auto parts store. They have universal ones.
Old May 31, 2021 | 09:36 AM
Flecker's Avatar
Flecker
That particular one runs on a slant across the battery and lines up with the holes/ squares in the tray for the threaded rods... The universals run straight across the battery (I have one of those now, looking to replace with the original bracket).
Old May 31, 2021 | 04:26 PM
mudbogger2's Avatar
mudbogger2
https://www.summitracing.com/parts/gmk-3021-301-67
Old May 31, 2021 | 06:52 PM
Flecker's Avatar
Flecker
Well shizzle! Thank you sir!
Old May 31, 2021 | 07:53 PM
77&79F250's Avatar
77&79F250
FYI that one above is metal (and very thin at that) and then plastic coated. The one in my pic is all plastic and heavy duty ish.....just saying.
Old May 31, 2021 | 08:47 PM
Flecker's Avatar
Flecker
Was the stocker plastic? I am trying to restore everything under the hood to the original state... I have some cheesey auto parts store bracket on there right now.
Old May 31, 2021 | 09:38 PM
77&79F250's Avatar
77&79F250
Not to sure on the OEM design or what material it is made of, but I do know that the one in my pic was NOT it. The OEM one (at least attached to the passenger side fenderwell for it to attach to) is a weird shaped 3 bend bracket that the OEM bracket attaches to.
mikey1968
Jul 31, 2018 04:31 PM
MikeIronTyson
May 29, 2018 11:03 AM
kwemj 67
May 14, 2009 09:44 PM
Trucky18
1978 - 1996 Big Bronco
Jul 14, 2003 05:09 PM
