I have a 78 f150 that I just got and most of the lights work however I don't have the parking lights that are under the headlights. Turn signals all work but those parking lights don't and when I turn the headlights on my turn signal lights inside are lit up but they still flash normally. does anybody have wiring diagrams that might work or advice to try I have checked and clean the grounds between the battery and the engine and the engine and the body thanks in advance
Ford used a 2 piece construction on the bulb holder sockets, not one the Better Ideas since the ground electrode is also 2 piece and can corrode inside the housing. I've replaced several and the first place I look when turn and signal lights are not working. Some aftermarket sockets may be wired incorrectly color to color on the wires.
The lights on the dash lighting up is a sign of a bad ground at the light not at battery to motor or motor to body but good you cleaned them.
Dave. ----
Have you tried replacing the bulbs? If turn signals work but parking lights don't, you could just have a coupla burned filaments. Do check the grounds too, both socket-body and through the socket. If your turn signals are a bit wonky, too, be sure to check the rear grounds - they can affect the fronts.
