ford pass app on android
any WHO at night i use the app to lock the doors and make sure i didnt forget. it then tells me the doors are locked and air pressure, dte and current miles on odo
if i lock or unlock with fob it does not update the info on the app.
yesterday i left my key in the house and unlocked using the door buttons, and thought let me see if it will turn on, not start but turn on. it did not ad gave me a message about no key detected.
so i locked the door and off i went
then a few hours later i checked my pass ap on the phone and it had updated the time when i pressed the key on event.
had no idea it would do that. not sure if its important, but interesting
i also use the app as a lo jack so i know when my wife is near home if she drives it
https://owner.ford.com/fordpass/ford...onditions.html
If your vehicle has connectivity technology (e.g. FordPass Connect or Lincoln Way modem or a Connectivity Device) and you connect your vehicle to your FordPass account, your vehicle will share Connected Vehicle Information (e.g. Vehicle Location and Driving Data) with Ford. Deleting or uninstalling FordPass from your device will not disable data sharing. Depending on how the vehicle is equipped, different in-vehicle controls may be available to you. Learn more about modems, other connectivity technology, in-vehicle controls, and in-App controls in the Owner’s Manual or call the Ford Customer Relationship Center. To stop FordPass-related vehicle data transmission and access enabled by connecting your vehicle to FordPass, contact the customer relationship center; and consult your vehicle's Owner’s Manual (and follow the procedure to disable your connectivity device which may require performing a Master Reset to stop data transmission.
Also from the same document:
Information we collect:
- Vehicle Location: Non-precise or precise location/GPS information, including current vehicle location, travel direction, speed, charging locations used (if applicable), and information about the environment where the vehicle is operated (such as weather, road segment data, trail and road surface conditions and geometry, traffic signs, and other surroundings, may be collected from the vehicle in connection with location-based functions of FordPass. Vehicle Location may also be derived from IP address.
- Driving Data (may also be referred to as Driving Characteristics and Behavior): Information about how the vehicle is operated and used (such as speed, use of accelerator, brakes, steering, seat belts, etc.).
- Vehicle Data (may also be referred to as Vehicle Information): Information about the vehicle, its components and parts, including their status and performance and diagnostics of vehicle systems (such as the VIN, hardware model and part numbers, odometer, tire pressure, fuel and fluid levels, battery and lock status, trouble codes, warning indicators, alerts, and SYNC diagnostics), vehicle charging information (if applicable), and other information about how the vehicle is performing.
- Audio/Visual (may also be referred to as Connected Voice Data, Digital Assistant, or Ford Assistant): Voice commands and other utterances captured when the vehicle’s voice recognition system is in “active listen” state.
Basically your truck is recording every single interaction you have with it and reporting it to Ford, but, hey, in exchange for that, they give us an app to geek out over.
my utterances while driving, oh boy .. i better get the soap ready.. that one slipped by me,
i am a sailor so there are no words i dont use in my expression of OTR trucks blocking the fast lane trying to pass a 65 mpg big rig while the passing truck is doing 66
Contrary to your reading of the Privacy Policy, your vehicle records audio and reports it to Ford. They admit they do it.
Furthermore, your position that you haven't had problems with the app for nearly two years doesn't have anything to do with OP's concern of data transfer he wasn't aware of. It's as if you stopped reading at the subject line of this thread, then decided to contradict Ford and ignore the topic. Weird.
