1978 - 1996 Big Bronco
1995 bronco e4od problems
Old May 26, 2021 | 05:29 PM
phillips91's Avatar
phillips91
1995 bronco with 210k miles. Was running great until about a week ago. Now when I am driving and it has to downshift or upshift on its own it free wheels like it’s in neutral and won’t engage in gear until I let off the gas and try again or I shift it manually. Then the OD light flashes and it shifts like it has a shift kit and won’t shift until about 3500 rpms. No one around here is checking codes due to COVID, so I can’t run a scan on it yet. When it’s shifting properly it shifts between all gears as normal, but when it starts disengaging it does it in all gears and not just one particular gear.
Old May 26, 2021 | 05:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Here is how to check codes yourself: www.troublecodes.net/ford
phillips91
May 27, 2021 08:10 AM
Fordkindagirl97
Jun 13, 2017 09:17 PM
Gribbletyler
Bronco II
Mar 23, 2012 09:06 PM
pshockley
Apr 1, 2006 12:50 AM
whistler
Dec 9, 2002 08:05 PM
