What are these for?
Old May 26, 2021 | 07:33 AM
sklbaj's Avatar
sklbaj
What are these for?
Old May 26, 2021 | 07:36 AM
sklbaj's Avatar
sklbaj
The blue piece is clearly not hooked up anymore. Just wondering what it was for? The other photo looks like a pump that is tied into the coolant lines that go to the heater. It has a 110v plug tied to it, and it has a coolant line that goes to the side of the motor.
Old May 26, 2021 | 07:46 AM
'65Ford's Avatar
'65Ford
No idea about the blue thing. The 2nd photo is a tank style block heater. They work great on engines that need them to start in winter time like diesel tractors. And you can set them on a timer to have your truck/car already toasty warm when you get in on a cold morning without having the engine idle for several minutes. They generate more heat (and consume more electric) than a screw in block heater because they're bigger. It doesn't have a pump, it circulates water/coolant by convection.
Old May 26, 2021 | 07:54 AM
sklbaj's Avatar
sklbaj
Thanks. Can I just remove it, and thread a bolt into the block when it goes in?
Old May 26, 2021 | 07:59 AM
davelj's Avatar
davelj
The blue can is for evaporative emissions. The hoses used to run to the air cleaner and such. As you can tell, it does not affect the performance or drivability to be disconnected.
Old May 26, 2021 | 08:23 AM
sklbaj's Avatar
sklbaj
I’m betting that block heater replaced a freeze plug. That stinks. If I put another plug in it’s place are they prone to leak?
Old May 26, 2021 | 08:57 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Kudos to the person who installed the tank heater. Usually they're installed on their side on the inner fender by the starter solenoid and then assumed to be bad since they weren't installed correctly.
Old May 26, 2021 | 08:58 AM
'65Ford's Avatar
'65Ford
You can remove it no problem. Two gallons of antifreeze will spill out. The hole in the block is pipe thread...maybe 1/4 inch? or 3/8...can't remember.
Just saw your comment on the freeze plug. It should not replace a pressed in style freeze plug...might but shouldn't. Lot of these older engines have pipe threaded plugs to drain the block. Use some pipe thread sealant and it will be good to go. Use a proper fitting tool to unscrew the fitting (i.e. not an adjustable wrench). They tend to be hard to unscrew after 50 years. If you're nervous about messing up the fitting, you could install a new short piece of hose and put a plug in the hose. And leave the screwed in fitting alone.
Old May 26, 2021 | 09:10 AM
'65Ford's Avatar
'65Ford
Yep, they do have to be at the correct height and correct side of engine to have good convection.
Old May 26, 2021 | 11:04 PM
jsc83's Avatar
jsc83
If you remove the evap system, you'll get a check engine light.
Gotta love these pre-computer cars.
Old May 26, 2021 | 11:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Charcoal canister used with the Evaporative Emission (Evap/Em) system on 1970/72 F100...CA required Evap/Em in sold new 1970/72 Passenger Cars, Bronco's, E100's and F100's.
Some other states may have also required Evap/Em as well.
Jamesglenn024
May 1, 2021 01:42 PM
lanneinbc
Apr 21, 2021 11:18 AM
95rustbelt250
Dec 27, 2020 07:23 PM
exbxtoy
Aug 11, 2020 01:53 PM
exbxtoy
Jul 17, 2017 02:20 PM
