I put new leaf springs on my trailer today. I tried to be consistent on both ends of the axle in how I placed the axle in relation to the leaf spring. The top and bottom bolts coming out of the leaf spring make it hard to get the axle badly out of alignment, but it seems to me that there is room for some fine adjustment. Less than 1/4", more like 1/8". Does it matter? Will my tires notice 1/8" of difference?
I haven't measured the axles center-to-center yet. I didn't have a tape measure.
There should be no play 1/8 is to much. It's called a centering bolt for a reason.
Denny
I got to thinking about it and that play is in the top plate where the u-bolts go through. The play between the axle perch and the leaf spring may be no more than a nudge. It's hard to tell.
Not sure how to handle this at home. I had mis-aligned axles from the factory that chewed up my tires on my Grand Design Imagine, and had a local spring shop fix them up.
There can be a lot of alignment issues and most can't be handled at home. If the axles are bend or improperly welded they will have to be bent back in shape. If the hangers weren't welded in the right place they will have to be cut off and moved. The front and rear hangers determines the axle placement and spacing so if they aren't in thre right locations you will get a lot of tire wear. What ever problem you have it takes a lot of measurements and specialized tools to do it right.
On our trailer I noticed toe in type wear on one front tire after 25K miles so I had the axles bent back into shape. Our axles are 8K and very hard to bend according to the alignment shop and its been done twice and everytime the front one goes back to the same wear pattern. It's not that bad and for $400 each time I just rotate the front and rear tires and replace the tires after 4 years.
One old dude at the spring shop said that GD had put "too light" axles under a bunch of trailers and it was causing problems. I dunno how many versions of the 3500 lbs axles Dexter makes. I wouldn't take financial advice from that dude, but he probably knows more about axles and prings than me. I shrugged.
When I first started looking at my ratings I was appalled. Two 5200 pound axles under a trailer rated for 11,000 pounds??? Then I realized that the tongue is carrying some of the load. Still, it seemed to cut it a little close.
Yeah, that's the standard. Trailers are designed for light weight and low cost first, and durability isn't in the top ten.
