Bad battery
Old May 25, 2021 | 07:02 PM
Bronkxone's Avatar
Bronkxone
Bad battery
II found the driver side battery leaking as it was wet on top and had run down both sides. Truck has under 10k on it and dealer said leaking would not
be covered unless it failed a test of some type. So I pulled both batteries and put in a set of Odyssey batteries. The hold down shows a fair bit of the acid
ate away at it. I used baking soda and water and cleaned the tray and all while the battery was out. Should I worry or is this just one of those things that
can happen?
Old May 25, 2021 | 07:28 PM
Sport45's Avatar
Sport45
You could have hit it with some spray paint after cleaning things up and neutralizing the acid. But no, I wouldn't worry about it. It takes a really long time for things like this to rust completely through and battery hold down bolts are cheap and plentiful.
Curious though, why didn't you let the dealer have a shot at it before spending the $$$ on new batteries?
Old May 25, 2021 | 07:48 PM
Ford Fx4's Avatar
Ford Fx4
They should have been covered. Both of mine were leaking @ 19k and were replaced under warranty
Old May 25, 2021 | 08:11 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Exactly!
Total BS your dealer telling you that a leaking battery wasn't a warranty deal, along with the acid damaged tray and hold down.
Old May 25, 2021 | 08:22 PM
KU4OJ's Avatar
KU4OJ
Don't go there for a leaky radiator. No, you got ripped, but now you have better batteries. I understand Ford OEM batteries tend to leak. If mine ever do I'll get Walmart's Ever Start. Not super wahzoo but best value for the money at that price point and nationwide warranty.
On edit: They have an AGM now at a good price point.
Old May 25, 2021 | 08:50 PM
ford390gashog's Avatar
ford390gashog
can happen?
Common, at least you made a great choice on replacements. They will last a long time.
Old May 26, 2021 | 03:40 AM
Bronkxone's Avatar
Bronkxone
I did hit the hold down with some paint before I put it back on. I asked the dealer and sent him a clear picture of it leaking and was told it was not covered.
I did not want to end up with more leaking batteries so I just replaced them myself. I do admit the dealers around me are Poo Poo so I just expect nothing
will be covered and that is just typical.
Bigdflyer
Mar 9, 2018 02:50 PM
NewXer
Jan 5, 2018 09:05 PM
Brotherbillstruck
Sep 9, 2017 08:39 PM
Neil64
15
Feb 28, 2010 08:25 PM
SuperSnake
Apr 21, 2008 02:38 PM
