died on the road today
Old May 25, 2021 | 12:24 PM
Old green123's Avatar
Old green123
Went out to lunch today, truck started right up, but then died two miles from home at a stop sign. I think, but not 100% sure, I had switched from front to rear fuel tank a second or two before it stalled. Now it will crank, but won't start. Both tanks have about 1/4 tank. i guess i will check the fuel pressure on the rail as first thing to look at ( on the side of the road!). any other suggestions where to start? thanks.
96 f-150 4wd, auto, 302
Old May 25, 2021 | 12:55 PM
jas88's Avatar
jas88
Did you try both tanks?
Try to start on starting fluid to see if your problem is spark or fuel.
Old May 25, 2021 | 01:03 PM
Old green123
yes, tried multiple times on each tank. Can you start/fire a fuel injected motor on starting fluid? I've never tried that.
I think my tank selector switch is good, as the gauge creeps up a bit when I switch to the rear tank, which has a bit more fuel.
Old May 25, 2021 | 02:36 PM
torq'ta 5 8's Avatar
torq'ta 5 8
It will run long as you keep spray/squirting it into intake, and that will let you know if its fuel, spark, or air, and what direction, to start looking.
Old May 25, 2021 | 02:53 PM
Old green123
I'll give that a try. I think it's not fuel, at least not the pump(s). Plenty of pressure when I release from the shraeder valve on the fuel line. Truck has run perfect for last 20k miles or so, was running fine until it died at the stop sign -- so I as figuring for sure the fuel pump wasn't cycling. But I can hear it run for couple seconds after turning the key, and getting at least some pressure to the valve.
Old May 25, 2021 | 03:07 PM
torq'ta 5 8
Get a gauge on it, to make sure, get help to check for spark, if starter fluid doesnt help it start.
Old May 25, 2021 | 03:32 PM
Old green123
I wonder if I can tow it with a chain and my wife's SUV, or if i need to call a tow truck. i'm only 1/2 mile from home, at most, but it's all uphill!
Old May 25, 2021 | 03:55 PM
GoinBoarding's Avatar
GoinBoarding
Whichever tank you were on before switching, go back to that, and turn the key to "on" but not the "start" position. This runs the fuel pump for ~1 second. Turn the key to "off" when you hear the fuel pump relay click. Then turn the key back to "on", wait for relay click, back to "off". Repeat this 5 or more times, then try to start the truck.
Something to try anyway. If still no good, get it home. Then start with checking fuel pressure at the rail. You can have fuel come out of the shrader valve but that doesn't mean there's much pressure.
Old May 25, 2021 | 04:09 PM
Old green123
thanks, I did that already. My boat has MPI, and has had some issues, so I've used that trick. i can hear the pumps going, on front or back tank. Tow truck is coming soon, and will start looking for spark first. assuming i have that, will go borrow a fuel pressure gauge I suppose.
I hate seeing my truck getting towed! especially when it's only 1/5th of a mile. But want to get if off the street.
Old May 25, 2021 | 06:37 PM
Old green123
Truck is home, now the fun begins. Putting a timing light on the main coil wire, or any plug wire - when cranking the motor not enough juice to even fire the timing light. I do have volts at the coil. The rotor does spin when cranking, and when I crank the motor with a voltage lead on what i think is the PIP wire, my analog volt meter is bouncing around 4 volts, maybe a little above.
Does this tell me anything? Bad coil?
I figured for 33 bucks, why not replace the coil. Had my self convinced that's where the problem was. I was wrong, new coil is on, still no spark.
Old May 25, 2021 | 11:30 PM
88n94's Avatar
88n94
If you have enough volts going up to the coil, usually 1 of 3 things causing a no start. The coil which you have already replaced. The PIP in the distributor and the ICM. The ICM, the ignition module, would be simplest to address, possibly you could find a parts place to test yours and save money if that isn't the problem.
Old May 26, 2021 | 05:55 AM
torq'ta 5 8
Old May 26, 2021 | 07:49 AM
Old green123
thanks, that's a good site. Of course I don't have an LED test light, or a regular test light, or an HEI spark tester - but will see what I can do. Might have to take an uber to the parts store this evening.
I have seen that i need to disconnect the PCM , and see if there is spark. Is it enough to pull the jumper out of the timing connector - or do I actually have to disconnect the PCM?
Old May 26, 2021 | 09:01 AM
sandymane's Avatar
sandymane
you remove the Spout not the pcm.
Old May 26, 2021 | 06:22 PM
Old green123
removed the SPout, no change. was only intending on buying some test tools at the NAPA, but they had the black module and the distributor in stock. So like the hack I am, threw two more parts at the problem, actually three more because I replaced the coil connector harness as that was one part which definitely needed to be replaced.
and still no spark. all the flow charts aren't helping me now - new coil, connector, module, and distributor ( and cap & rotor). have positive at the coil, negative does not pulse when cranking.
