Auxiliary tank recommendations
Old May 25, 2021 | 11:37 AM
RigCity's Avatar
RigCity
I’m looking for one of the 100-125 gallon auxiliary L shape tanks that goes under the toolbox. It would not be used too often but it’s a piece of equipment I’m looking to get. Is there a way to protect the steel from rusting during long periods of sitting or should I get an aluminum tank?
thanks
Old May 25, 2021 | 01:33 PM
sjbj's Avatar
sjbj
Tagging this one as I'm also in the market for an auxiliary fuel tank....
Old May 25, 2021 | 09:44 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I bought an ATTA 45RBR years ago and use it all the time. They will build you a tank to your specifications if you like. Give them a call, they were willing and open to answer all of my questions.
I selected the 45RBR because I have a roll up soft bed cover that I use, even when towing the 5th wheel. The cap sits below the bed rail, so mo interference from the tank regarding the bed cover.
It is pricey, but you can get just the tank, which is still pricey. Mine came with everything I needed including switch, 12v pump, sending unit, wires, gauge and hoses.
It has been filling my truck at 65 MPH for years and I will never not have an auxiliary tank on my truck from here forward.
Old May 29, 2021 | 09:45 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I'd suggest an RDS aluminum tank. We are a dealer, let us know
Old May 29, 2021 | 09:47 AM
sjbj's Avatar
sjbj
I might be interested when timing is right. The only issue I've read on reviews from RDS is usually horrible packaging and they get damaged during transit....
Old May 29, 2021 | 09:51 AM
Bitterroot Diesel
Former Vendor
They are strapped to a pallet. Sometimes the shipping companies don't do a great job. Order the tank before you need it because there are long lead times in manufacturing these days!
Old May 29, 2021 | 09:47 PM
MountainManRobb's Avatar
MountainManRobb
If you get a steel tank, I guess you could try Red Kote on the inside of the tank, or whatever chemical company you prefer. I am not sure about how much fun or easy it would be to slosh all the nooks and crannies on an L shaped tank, but it is a possible option.
Old May 30, 2021 | 11:05 AM
jgg123's Avatar
jgg123
I have the RDS 72545, works good for me but I have a topper. Wouldn't work as well if you had a box cover as it sits above the line.
Anyways, its a tank, and it holds diesel. Couldn't quite get the auto fill fitting to sit straight up and down in the fill line, not enough clearance in my application.
montey2005
6.7L Power Stroke Diesel
Dec 2, 2012 08:58 PM
rocketman2440
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 7, 2012 10:05 PM
johaner78
Aug 30, 2009 08:21 PM
6.9OriginalDiesel
Jun 15, 2007 08:44 AM
