Question with heads
Old May 25, 2021 | 09:20 AM
77 HOS's Avatar
77 HOS
Question with heads
1. One of the head bolts (top left rear and top front right) I can see thru the accessory mounting bolt holes and see the shaft of the head bolt. Is there a risk of oil wheeping under the head bolt, down the shaft and out the holes? Should I put a little silicone in there to plug thru the accessory mount hole or dont worry bout it.
2 while setting lifter preload I noticed a little black mark on a small plug, turns out to be exhaust port plug rusted. Should I replace it with another plug of the same type. Or is it better to 1/4 tap the hole and stick a plug in there. Feel like the plug will never go bad. Has anyone else done that?
Thanks
After poking at it a little
Old May 25, 2021 | 11:40 AM
Crop Duster's Avatar
Crop Duster
Don't worry about that head bolt it won't leak. That plug needs replaced however you choose to do it.
Old May 26, 2021 | 01:17 PM
77 HOS's Avatar
77 HOS
Thank you for the info. Ive decided to go with new plugs vs tapping the hole 1/4npt and thread plug in. The hole measures .5 inch and thats a little larger than the drill size needed for 1/4npt (.4375 or 7/16") the push in plugs should be the path of least potential issues.
alaskarat
1997 - 2003 F150
Oct 26, 2016 01:53 PM
jrockdiddy
17
Jan 12, 2016 09:49 AM
bigredtruck
13
Feb 20, 2007 12:08 AM
6t6merc
Jun 8, 2004 09:21 AM
