Pro Comp heads have a freeze plug. Why?
Not sure. I did put on a new weiand intake manifold that doesn't have the water port crossover on the rear. The heads do have a water port.
The best way is to machine threads into the hole and use a threaded plug. The only question that I have is why is there so much pressure that caused the plug to blow in the first place? Radiator pressure should never be enough, do you possibly have head gasket issues?
Was the engine fully warmed up (thermostat open) when you did this burnout?
Here is a pic of my engine with the Edelbrock 2181 and the ProComp heads:
CharlieLed, are you using brass plugs?
I am having a difficult time finding plugs to fit these heads. i measure 1.15 in diameter. maybe 1 3/16 brass plugs might fit???
The heads are made to mount to either bank of the engine so they must have a water port at each end. The manifold only needs the water crossover at the front where the water outlet is located. On my 351W with an Edelbrock 2181 manifold, there is no rear crossover either. I too am running ProComp heads. There may also be an issue with corrosion between the plug and the aluminum head. I am running Evans waterless coolant for just such a reason.
I have never given these plugs a second thought...before today I had never heard of anyone having an issue with them. The ones in my heads are the ones that came with the heads. Given that measurement and understanding that these heads are cast off-shore, I think that a 30mm plug should fit... Nissan Factory OEM Freeze Plugs 30MM Pack Of 5 - 00933-1301A
First off you can stake them like you do to the oil galley plugs to help retain them. Next there does not appear to be any sealant on that plug hole, sealant helps retain them.
As to what Wayne said I believe he may be slightly right, I was told by several old ( and I mean long dead old) mechanics that they are freeze plugs because as the water freezes and expands the plug is supposed to be pushed out thereby avoiding cracking the block or head. They are also used for the casting process.
Should get two plugs tomorrow at 10am. I'll report back. I like the "staking" idea. I did that to my oil plugs behind timing cover
My father had a 71 Ford Torino with a 302 that froze one winter. The "freeze" plugs never budged. But the heads and block both had chunks of cast iron blown out in quite a few places.
I never believed the "freeze" plug thing since. A little OT but, I felt it may clear things up on casting or core plugs.
If the casting does crack with frost and you have very rare engine there is an amazing process called cold stitching that can save it from scrap. Not many people around who can do it though.
