289 head question
Old Jan 30, 2007 | 12:09 PM
bigredtruck's Avatar
bigredtruck
289 head question
I just got a 67 Cougar with the 289 in it, and have an exhaust leak that I cannot figure out.
There is a hole on each head just forward of the front most spark plug on the passenger side, and rearward of the back most spark plug on the drivers side.
It is on the same face as the exhaust ports, not on the ends of the heads where the thermactor ports are. I though I had leaking exhaust manifold gaskets, but these two spots are where it is all coming from. Does anyone know what the holes are for? It looks to be about 3/4" diameter with a 1/4"-20 hole further in it and the 3/4" opening is not threaded. When revving the engine, my brother says flames come out in bursts, so I assume it is tied into the exhaust ports somehow, but I have no clue. It is in the same exact spot on each head if they were set next to each other.
My experience with 289's is zero, I have only built Clevelands before buying this car.
Thanks,
Robert
Old Jan 30, 2007 | 12:33 PM
Conanski's Avatar
Conanski
That sounds like where the air injection should go.. but honestly I didn't think these old motors had that. In any event you should plug these holes.
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967 was second year for T/E pumps, and the smog manifolds had four outlets per side, leading directly into the heads...not at the front/rear. Ford made a threaded tapered hardened plug to close off the holes when T/E was not used.
Old Jan 30, 2007 | 01:17 PM
bigredtruck
Any leads where I can get these plugs from?
I read on a Cougar website that a 5/8"-11 bolt will plug the Thermactor hole, but that is on the end of the head where accesories bolt to. They don't mention anything about holes on the same face as the exhaust manifolds.
Thanks,
Robert
Old Jan 30, 2007 | 04:32 PM
HemiEater's Avatar
HemiEater
something don't sound right...it's on the same side as the exhaust manifold.....? not on the ends?
Old Jan 30, 2007 | 06:25 PM
bigredtruck
yep, its on the same face as the exhaust manifolds. I will take a picture of it tomorrow to clarify.
Old Jan 30, 2007 | 07:08 PM
NumberDummy
FTE Sponsor y2kparts can prolly get the plugs.
And for the "Doubting Thomases" out there...most of the T/E systems prior to the 1980's used smog manifolds which lead directly to the heads above the exhaust manifolds, on V8's (4 tubes for V8's.)
Some systems use a crosspipe at back of heads, or a pipe into front of heads. There are tons of variables.
The manifolds used a nut and ferrule (parts were available separate), which screwed into pre drilled holes in the head. First use of this system: 1966.
(1963 Falcons didn't have smog pumps )
Old Jan 30, 2007 | 07:52 PM
HemiEater's Avatar
HemiEater
Doubting Thomases?????
what does a 63 falcon have to do with it????
never seen what you guys are talking about.......I'm all ears and eyes here boys!
Relax Man.......
Old Jan 30, 2007 | 07:57 PM
HemiEater's Avatar
HemiEater
Would like to see it...never seen one...
Old Jan 31, 2007 | 04:27 AM
NumberDummy
Talking 9a486
Relax Man.......
j/k I was ragging on you a bit...and I can tell a 63X from a 62X...that's Ford partese for a 63/62 Falcon.
Beginning in 1966, all the smog pump systems (6 or V8) used the manifold to cylinder head system. It's a whole different system than used today. If you email me off FTE, I can scan and send.
Old Jan 31, 2007 | 04:31 AM
HemiEater's Avatar
HemiEater
[QUOTE=NumberDummy]j/k I was ragging on you a bit...and I can tell a 63X from a 62X...that's Ford partese for a 63/62 Falcon.QUOTE]
what?
Old Feb 3, 2007 | 10:47 AM
StangMan's Avatar
StangMan
What we have here is... failure, to communicate...
Old Feb 3, 2007 | 05:02 PM
HemiEater's Avatar
HemiEater
got that pic ???
Old Feb 20, 2007 | 12:08 AM
bigredtruck
Sorry for the delay. I added an album to my gallery showing the plugs I had to make to fix the exhaust leaks.
