proportioning valve
Old May 25, 2021 | 07:29 AM
lomesome1's Avatar
lomesome1
Wink proportioning valve
I will be putting the brakes on my 56 soon as i get thru sand blasting the frame. Going to update what the plans are now. Putting dropped axle, with new spindles and bushings, disc brakes, booster and master cylinder, 9 inch from a 62 thunderbird, 4 link with coil overs. now for my question. where would be the best place for an adjustable proportioning valve? Thanks for letting me bend ur ears.
Old May 25, 2021 | 07:39 AM
fatfenders's Avatar
fatfenders
I have always placed them forward on the frame and out of sight. I've never owned an adjustable P-valve though. As long as I used one with the appropriate front to rear disc vs drum combo it always worked out very well. Adjustable was always plan B but I never needed to do it.
Old May 25, 2021 | 08:15 AM
lomesome1's Avatar
lomesome1
don't know which one would be the right one.
Old May 25, 2021 | 08:16 AM
lomesome1's Avatar
lomesome1
It is going to have disc on all four.
Old May 25, 2021 | 08:30 AM
fatfenders's Avatar
fatfenders
Nor do I but my build was partially used parts from the salvage yard just to keep the overall cost somewhat close to sane. Threw a P-valve in the parts pile and paid a couple bucks for them. Generally speaking a P-valve distributes 70/30 front to rear. A modded truck is a grand trial and error experiment. A valve off most any car or truck has a high probability of working fine. I happened to used old Ford Econoline van stuff. Don't let me cause you any stress. An adjustable P-valve will do fine. I just spent the money on something else because I knew it was highly likely to work out and it did. Brake line fittings are stupid complicated with new one off metric fittings. I wouldn't go grab a valve off a random anti-lock equipped car today.
Surveywaters
21
Oct 15, 2020 08:02 PM
MarkAnderson
Apr 1, 2017 06:47 PM
dyoungen
Apr 19, 2015 09:15 PM
Jpotter57
Jul 31, 2008 07:58 AM
51ford fan
Jan 8, 2005 02:35 PM
