Compatible rear end
Old May 24, 2021 | 05:59 PM
Thurston Jamie's Avatar
Thurston Jamie
Compatible rear end
I have a 1964 F350, years ago before I bought the truck the dual wheel on the rear were stolen so now I have a SRW. I use this truck to haul a bit of wood and hay for the farm from time to time. As the likely hood of finding a set of usable dual wheels located in Eastern Canada is slim to none I am curious what other years 1 ton rear end will fit with minimum modification. Ideally I could find a donor truck and swap the front end out and make it power steering.
Thanks
Jimi
Old May 24, 2021 | 06:06 PM
DrCharles's Avatar
DrCharles
I believe a Dana 70 from a '68-'72 F-350 will fit (it's an 8-lug so at least there are dually wheels commonly available). It's been 20 years but I think only the brake hose (frame to axle) needs to be replaced with a '68-'72 also. Original was 4.88 and so was the replacement.
That's what I did with my '65
Old Jun 17, 2021 | 09:23 PM
Thurston Jamie
Will any dana 70 fit, I'm sure it would be easier if I can widen the search.
Kevin Cwb Stpierre
Aug 4, 2015 07:26 AM
Mrboylston
Mar 1, 2010 09:33 PM
projectdagger
Nov 8, 2009 11:18 PM
markjw
Aug 4, 2006 07:06 PM
bwhalen
Oct 24, 2005 07:19 PM
