Rear end replacement
Old Aug 3, 2015 | 12:46 PM
Kevin Cwb Stpierre's Avatar
Kevin Cwb Stpierre
Hi guy's I'm new to this world of Diesel and I'm wanting to change my rear end from dually to just a 2 wheel rear end is this possible and what would it intail to do this
Old Aug 3, 2015 | 04:09 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
just take the dual rear wheels off and bolt a set of single rear wheels on. this way if you need to put the duals back on to move a heavy load it is a simple matter of taking the single off and putting the duals back on. it is easy to put a single wheel on a dually rear, it is hard to put duals on a single rear wheel rear..
Old Aug 3, 2015 | 08:33 PM
Macrobb's Avatar
Macrobb
Originally Posted by tjc transport
welcome to FTE.
Nope!
All you need is an aluminum spacer disk with studs.
It pushes the mounting surface out a couple of inches(basically as long as the existing studs), which allows for 2 offset wheels to be installed back to back.
This is what my dad has on his F-350 4x4; PO used it to haul a /heavy/ camper. Bearings are still in good shape.
Old Aug 4, 2015 | 07:22 AM
tjc transport
i ain't rite
until the tires hit the side of the bed ripping the sidewalls out of them
Old Aug 4, 2015 | 07:26 AM
Macrobb's Avatar
Macrobb
Uh, what?
As long as your tires are spaced correctly(In this case, the aluminum spacer compensates for using an offset rim instead of the stock rim), there should be no more clearance issues than stock.
And I'm pretty sure this was an aftermarket kit of some sort.
C350CREW
Jan 21, 2024 06:35 PM
shark1979
Mar 15, 2010 09:25 PM
projectdagger
Nov 8, 2009 11:18 PM
rhino1
Dec 6, 2006 04:47 PM
Sherlock101
Oct 7, 2002 09:28 AM
