I have an 80 and I'm pretty sure my valve is just a open when cold closed when hot. And that's all I really need it to do. I put my new warm air bypass on and im not getting enough vacuum to close it. I'm assuming cuz the bimetal valve isn't functioning properly or is just clogged.
Soak it in solvent and blow it clear with carb cleaner.
The best way we in hot climates can test it is to pack it with ice for 15 minutes, start the engine, watch the flapper close, remove the ice, and wait for it to open.
Mine also doesn't have a metering valve in line with the vaccume hose from the actuator to the switch
If you are referring to the one way valve in the vacuum supply line, not having it will make the flapper slam closed when you stand on the throttle. It is there to hold vacuum when the mmanifold vacuum drops.
IIRC, that is the exact part for an 83 4.9. I can't think why it would be different in other engines.
Are you planning on running both actuators/motors from one of those regulators? If so, it will probably be fine initially and when warm, but the intermediate positions may be less than optimal. This is because there is a calibrated leak in the system to get one flapper "just right" at mid range temperatures. Add a second motor, and the balance will change.
Your winters are similar to ours here in Houston. I doubt my truck stays fully open for more than 5 minutes, and it probably has minimal impact after that.
If there is a issue then to correct it would be to source the temp sensor for a Mustang that used the dual snorkel design air cleaner.
I keep going back and forth on the dual snorkel myself. Part of me thinks I could benefit from the extra air flow but then I hate the thought of relocating my oil fill to the passenger side rear where it will be even harder to pour oil in. For me I would hook it up but wouldnt care to have it functional. If you have a carb then you really need it functional. I dont think even with aftermarket EFI you could have a benefit of having it functional. About the only benefit it could provide with EFI would be the whole helping to warm the engine up quicker by ingesting warmed air over ice cold air.
The above is incorrect. But I could understand why someone would think this.
If the flappers were a metered leak and relied on flow to operate them it would be true. But they rely on pressure to operate not flow. The regulator regulates the pressure or vacuum in the line to the motor NOT the flow. The motor is a dead end in the circuit in terms of flow. The regulator is just adjusting the pressure in the hose that is hooked to the motor, and remember that hose dead-ends at the motor no flow.
You could hook 100 actuators/motors to a single regulator it and it would still function exactly the same, of course, the response time would be much slower since you are adjusting the pressure in an area with a much larger volume but you are still just adjusting the pressure to the same value as if one motor was hooked to it, and that is what the actuator responds to pressure not flow.
So with 2 motors, it will work exactly the same as if one motor was hooked to it, just the response time will be milliseconds slower
That is how I see it as well. One can apply vacuum to the motors themselves and it will hold vacuum. They quit working when they stop holding vacuum and cant overcome the spring in the motor holding the door in the open fresh air position.
I'm only using one motor/actuator. Was going to hook up both but one of the actuators I bought the rod for the diaphragm is way off center and doesn't hook the flap right. It was only 4 bucks from rockauto so It's not even worth returning.
On another note the part number in the link above works but the ones I got the rod was about 1/4 inch shorter than it needed to be. So I had to finangle it a bit to work
Don't sell these innocent looking temp sensors short. I don't know about the new one you bought, but I had one that looked like your earlier picture, and it actually modulated the damper door and had middle positions. On one of these units I read that it tried to keep the intake air at 100 degrees, so I would think on most cold starts the damper is going to be shut except on the hottest days.
On mine that looked like your first picture I unclipped the plastic cover, and started playing with the sensor as the engine was running. It even had an adjustment screw. I didn't adjust it, but I did mess with it, experimenting on how it worked, and it started working fine afterward. It must had come corrosion on a piece of dirt in it somewhere.
That makes perfect freaking sense. When I Installed it on the truck it was already afternoon so that coulda been why it was just open. One of those things lol. I figured the trucks cold right? Didn't even think about ambient temp. Haha
