Build Sheet
Old May 22, 2021 | 08:00 PM
blackelim's Avatar
blackelim
Build Sheet
For you guys that have a Canadian built truck.
I was removing the roof insulation and when cleaning out the inner structure channels around the perimeter of the cab I found the build sheet for my truck.
It was above the rear passenger door.
As found
after adding a little moisture
Old May 23, 2021 | 09:27 AM
flowney's Avatar
flowney
Looks like one of the dead sea scrolls except for the perforated margin which tells us that it was run through a dot matrix printer most likely controlled by a mainframe computer. The first widely available micro computer (Apple II) wasn't on the market yet.
Old May 27, 2021 | 12:48 PM
Light Blue Oval's Avatar
Light Blue Oval
Wow, that's even cooler than a Marti Report.
Definitely worth taking to the local print shop and having it laminated...
Cooter was built in California but resides in Canada now...
I might just pull the headliner and have a look.
Old May 27, 2021 | 01:03 PM
jakeharp's Avatar
jakeharp
Thats cool, love old documents, wish i had my build sheet, someone put ghetto bucket seats in my ride so no sheet in the seat....
Old May 27, 2021 | 11:33 PM
blackelim's Avatar
blackelim
It's pretty brittle, I wish I knew more on how to preserve old paper items, I don't know if it would survive a trip through the laminator
Old May 28, 2021 | 04:27 PM
GordoNorte's Avatar
GordoNorte
That is indeed cool! Great find and that you were able to flatten it without further damage. Perhaps placing it between two pieces of pexiglass holding the edges with several binder clips? Just a thought.
I always look for these build sheets, found for both my '91 and '87 trucks, both Canadian built. Sheets were under the bench seat tucked between the foam and steel mesh, PITA to remove without tears as the paper is quite brittle. So yours was on the roof inside the headliner? I have a '76 also, will definitely look for it as it was not under the seat (not sure if the locations are standard?). Don't know also where it is on the '90 with captain seats...
The comment about being dot matrix print, apparently this was practice well into the 90s...
56panelford
1069
May 15, 2026 08:38 AM
56panelford
864
Apr 4, 2026 03:29 PM
ruger761
91
Feb 26, 2020 08:46 AM
monstergarage87
Mar 15, 2013 09:43 PM
48fordcoe
20
Dec 24, 2008 03:07 PM
