Sponsored by: Real Truck
Problem with 5r110w
Old May 22, 2021 | 08:40 AM
dustin hill's Avatar
dustin hill
Problem with 5r110w
I turned truck off and when I started it and tried to put in gear had a whining noise and no gear so pushed it to a parking spot . Then waited like 5 minutes started it and it went into gear. So do I have a trans that is goin out or did it hiccup? This is on a 2007 f250 6.0 diesel 4x4
Old May 22, 2021 | 02:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low trans fluid could do that. Check it with the trans warmed up, in park, and the engine idling.
Old May 22, 2021 | 03:00 PM
dustin hill
Mark
I checked the fluid and it’s good no burn smell and is red in color
Old May 22, 2021 | 06:01 PM
Mark Kovalsky
Is the trans fluid low, or filled into the hot range?
Old May 22, 2021 | 06:11 PM
dustin hill
Mark
Filled to correct level I’m wondering if I need to check the line pressure
Old May 22, 2021 | 06:13 PM
Mark Kovalsky
That would be the next step.
Smirks90
2009 - 2014 F150
Jun 18, 2015 10:30 PM
whalepirot
May 14, 2015 05:34 PM
kupiec20
18
Nov 22, 2013 10:09 PM
klassik1
May 15, 2013 04:36 AM
#8trx450r
Jul 24, 2007 08:19 PM
