Parking brake on automatic
Old May 20, 2021 | 08:50 AM
RacinJasonWV's Avatar
RacinJasonWV
I see what you did there. I'll just leave this here.
https://youtu.be/1U-gVZyvIsw
I hate to say that was funny but…
I didn’t see any reverse light blink before he shut it off so I’m guessing it was left in drive and not actually a parking pawl failure. But yes, consistent use of the “parking brake” would have prevented this mishap.
I’m living on the edge.
Old May 20, 2021 | 08:58 AM
FordTruckNoob's Avatar
FordTruckNoob
Seriously though, I always left all my manual transmission vehicles in gear when parked because you never know when a parking brake might fail too. If it was a track vehicle that had just come in from some laps and the brakes were hot, then the vehicle got parked in gear and the wheels were chocked, leaving the parking brake disengaged so the pads wouldn’t burn themselves on the hot rotor. The point is to never have a situation where a single point of failure can cause your vehicle to drift away unexpectedly.
Old May 20, 2021 | 09:34 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Well I call it an “emergency brake” so….
My take on this is even funnier if you knew what I did for a living. Sorry, can’t say though.
I have had issues in the past with sticking “parking brakes”. Especially with higher mileage and rarely driven vehicles. It has kinda made me gun shy. Yep I could fix them, but they seem to stick unexpectedly at the most inconvenient times. The pawl will hold my stuff under most normal conditions and I reserve the E brake for emergency situations.
Now back when I had the OBS with the ZF the brake was used frequently during trailer connection timing.
P-brake or E-brake, it is what it is...
You forget, I DO KNOW what you do for a living... We have had this conversation on the phone before...
They only stick until you burn them up... Then, they will be new or non-functioning.
All good @RacinJasonWV and when we are laughing about this over a cold beverage at the PA GTG, it will be good times.
Old May 20, 2021 | 09:37 AM
Sous's Avatar
Sous
FTE Emeritus
Yes, when parked with engine off, the truck is in L or R. Same with the manual transmission cars we have owned. I just look at the P-brake (not E-brake) as a means to ease stress on the transmission, be it automatic or manual. If the P-brake happens to slip or fail, then the transmission will stop the vehicle from rolling away and stopping abruptly.
Old May 20, 2021 | 09:43 AM
Walleye Hunter's Avatar
Walleye Hunter
Old geezers call them emergency brakes, youngsters don't know any better and call them parking brakes.
Old May 20, 2021 | 09:47 AM
Walleye Hunter
As for making the cable brake work again...In addition to the aforementioned cable chafes on the frame, there are actuator assemblies in the back plate of the brake system, which rust fast and will result in the cable brakes not working. To get to them, you have to tear the brakes apart and either replace them or work on them to get them functional.
Old May 20, 2021 | 10:02 AM
RacinJasonWV
Oh yes I knew that you know but others don’t. Am I correct in it makes it all the more ironic?
And I hope the E vs P came across as funny. That was the intent. Although it was the truth as I must be an old geezer since it truly is an E brake to me.
Convincing argument. You may persuade me to come to the light side eventually.
Old May 20, 2021 | 10:31 AM
FordTruckNoob
Ohfishul Knowmenklaycher man!
That's why Audis have electric parking brakes.
Old May 20, 2021 | 10:42 AM
00t444e's Avatar
00t444e
The Parking brake isn't that good when it is working.
Old May 20, 2021 | 10:43 AM
Sous's Avatar
Sous
FTE Emeritus
What is the age cutoff for "youngster"? I took an "are you a millenial" test a few years ago with a few other SNCO's and the closer to 50 you were a millennial. I scored a 4... Yes four...
Yes, entertaining and ironic to say the least. It did and does come across as funny Jason.
How many times did you have to type that out before you were happy with it?
You should write CL ads for a living...
Old May 20, 2021 | 11:14 AM
FordTruckNoob
Alright alright alright. How does one join the cool kids' club? Or is this a Goof Troop dealio?
Only about 20. My method acting classes are paying off. I've catfished some Northern MN types with offers of a sister's virginity for sale.
Old May 20, 2021 | 05:56 PM
RacinJasonWV
OK, you’ve got me there.
As do some other makes. Which I believe may have a lot to do with people doing things like seen in your video. Can’t roll away due to forgetting to put in park if the PARKING brake comes on itself…
PancakeF150
Apr 30, 2021 02:17 PM
MarkRogers
Oct 2, 2017 12:15 PM
RJ sheedy
15
Nov 15, 2016 04:41 PM
rgconway
Jul 3, 2008 01:05 PM
John Totten
Aug 30, 2003 10:58 PM
