1992 F-150 Starting Issues
Old May 18, 2021 | 04:18 PM
Owen S.'s Avatar
Owen S.
Question 1992 F-150 Starting Issues
Hey Y'all, ive have my 1992 F-150 4.9L EFI 2WD for almost a year now and just recently its been having starting issues, The biggest issue is that the truck will crank super slow when it gets up to temperature. Ive replaced the starter, and ignition solenoid on the fender and it has a newer battery with plenty of CCA's and it's the right size. But when i go to start it, it just turns over super slow, i've looked through the forums and most i can tell everyone says new solenoid or starter but i've already replaced those and it's still having the same issue. The other issue is that it wont turn over with the key, the key will work fine in the ignition barrel and i can turn the key to the starting position and it puts a draw on the battery so i know the key is sending power out but i dont know if it's getting stopped on its way to the solenoid, ive checked all wires from the solenoid to the starter and even put a new chasis ground to both but its still having the same two issues, ive replaced the fender solenoid twice and ive rewired the terminals, the only way i can get it to start is by jumping the fender solenoid and then when the truck is warm it will crank very slow and after a few seconds the wires on the battery will start to smoke a bit so that makes me think bad ground but im pretty sure ive checked all grounds, any info or knowledge is helpful and appreciated, thanks. -Owen
Old May 19, 2021 | 08:52 AM
jas88's Avatar
jas88
If you crank the engine with it warmed up, but the key off, does it still turn slow?
Old May 20, 2021 | 09:36 AM
Owen S.'s Avatar
Owen S.
No it doesn't, with the key in the off position jumping the solenoid it turns over nice and fast
Old May 20, 2021 | 10:30 PM
1MoreFord's Avatar
1MoreFord
I had a '88 that would turn over Slowly when hot with the AC on. Turn the AC off and it would turn over fine. Just something to try.
Old Jun 1, 2021 | 01:41 PM
Owen S.'s Avatar
Owen S.
It does it with the AC off aswell, it's definitely a sketchy thing to drive too considering it's a manual, and if i stall in traffic i have to wait for it to cool down before it can start again
Old Jun 1, 2021 | 03:39 PM
88n94's Avatar
88n94
Have you checked the ignition timing? I believe it should be ten degrees BTDC and if it was too far advanced you would experience pinging under quick acceleration. If it is set correct I would try retarding it about 5 degrees to see if it helps.
You would still need to get it to crank over from inside the cab, if all else fails I would rig up a push button starter switch.
Old Jun 2, 2021 | 09:45 AM
jas88's Avatar
jas88
That tells me your initial timing is too far advanced.
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
ptboi94
Nov 10, 2010 03:07 PM
ToolDude
17
Apr 22, 2004 02:37 AM
gunner9821
Electrical Systems/Wiring
Feb 24, 2004 10:16 PM
kev100
Apr 9, 2003 02:18 PM
