Starting problems
Old Feb 24, 2004 | 08:34 PM
gunner9821's Avatar
gunner9821
Starting problems
I have a 1994 F-150 and it will not start at times. The battery is fine and I recently replaced the starter. I was able to jump across the solenoid on the fire wall and it started, however I had to make the contact several times. It just clicked about 10 times or so, then it finally fired. Any ideas ???
Old Feb 24, 2004 | 10:16 PM
sparky's Avatar
sparky
Could be the internal power contacts on the solenoid are pitted/worn and it is time to replace the solenoid.......does it click the same when you turn the key???? If so my money is on the solenoid
