Did I buy the wrong Bilstein
Old May 18, 2021 | 01:53 PM
houstontxex's Avatar
houstontxex
I bought this this as advised by Bilstein from an inquiry through their website. Part #33-185569. Rear shock. The bar pin from ProComp shock will not go through Bilstein upper mount. Was told by them to source a pin from 4wl parts, summit that will fit through 5/8 hole. Someone else gave me the idea that the correct part might be 33-236964. Hope someone can help sort this out.
2005 RWD (2WD)
ProComp lift 6"
Old May 20, 2021 | 08:42 AM
Terracar's Avatar
Terracar
I can confirm they do come with the proper mounting bracket on the top (assuming 2WD is same as 4WD models). I would take a pic, but they are already installed right now.
I am unable to confirm if the 33-236964 will work for a 6" lift (I got them for a 4" lift).
-Terracar
Old May 20, 2021 | 10:30 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
hose down the rubber bushing with WD40, and press the pin into the bushing using your vise as a clamp.
do not cram it completely through in 1 try, rather unclamp it and wiggle the bar around to keep it going in straight without gouging the rubber.
of go caveman style and set the shock eye on a block of wood being carefull not to let the shock body touch, coat bushing with wd40, tap the bar into the bushing to get it started . once started give a heavy rock to a 10 year old and tell him to knock it home in 1 whack while you hold the shock.
Old May 20, 2021 | 09:05 PM
houstontxex
Thanks Terracar and Pirate. Pirate, thank you I look forward to cavemaning that bar in. Another question posed by someone else is if the shocks are valved for my rig. That sounds like a good question for Pirate...
Old May 20, 2021 | 11:57 PM
pirate4x4_camo
FTE Remembers
No not vehicle specific valving, those are custom fit. they should be fine if you have 35" tires,
you will not find a vehicle specific shock for a lifted RWD,
Old May 22, 2021 | 07:06 PM
houstontxex
Thank you for easing my mind, I can plan on going forward when I get the chance and not have to do a return thing. Appreciate the help.
youknowitdadio
May 11, 2020 03:25 PM
woodson84
Sep 26, 2019 07:02 PM
sammatt1
Sep 25, 2017 05:02 PM
400inatruck
May 24, 2012 10:31 PM
BucksTrucks
Offroad & 4x4
Mar 15, 2009 10:00 PM
