12v charge wire
Old May 16, 2021 | 08:01 PM
meborder's Avatar
meborder
12v charge wire
Not having the full factory towing package and not being able to locate the factory wiring I had to run a 12v trailer charge wire from scratch.
i used 10awg wire from the battery post to the plug in the back through a 20amp breaker.
there is no relay to turn the wire on/off. Just the breaker to protect the wire.
any problems with running direct to the battery in this manner? I’ve seen a few trucks wired this way in the past and have never seen an issue, but I thought I’d ask.
i really wanted to tap into the factory circuit, as all the fuses and relays are there, but it’s location is not easy to find.
Old May 16, 2021 | 08:14 PM
ford390gashog's Avatar
ford390gashog
What vehicle is this? There is no issue the way you did it but there is nothing to stop the trailer from killing your starting battery. A switched relay would have solved this.
Old May 16, 2021 | 08:39 PM
meborder's Avatar
meborder
It’s the 2014 expedition.
i agree a relay would be best, but I’m short on time and locating wires on this thing has been a nightmare.
I think long term I will look for a better solution, but for now if it doesn’t represent any inherent problems, I’m going to run with it.
If I have any kind of load in the camper I will unhook the plug to be safe.
Old May 16, 2021 | 09:05 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
No problem with doing that but like @ford390gashog said it could kill your starting batteries, especially if you are in a parking lot for a few hours and something in the trailer kicks on. Also without a timed relay you could also pull from the trailer while starting and the breaker may not catch the jump in Amp's fast enough to protect that wire and connector.
78Fordbc
21
Apr 8, 2014 07:00 PM
iMakana
Aug 13, 2010 12:28 AM
jetact
All Things Towing
Jan 3, 2006 01:06 PM
baitmaster
Electrical Systems/Wiring
13
Feb 12, 2005 05:40 PM
taurus8
All Things Towing
Nov 10, 2003 05:35 AM
