wiring help
Old Aug 11, 2010 | 11:28 PM
iMakana's Avatar
iMakana
wiring help
Im having soem trouble with my <nobr>truck</nobr> and I was wondering if anyone could help me. I can't seem to find my constant wire in my truck. It's a 1981 F-250. Can anyone help me?
Old Aug 12, 2010 | 08:51 AM
Franklin2's Avatar
Franklin2
What is a constant wire? What is wrong with the truck?
Old Aug 12, 2010 | 09:46 AM
masseysbronco's Avatar
masseysbronco
I think he just means a wire that is hot whether the key is on or off. You can always run a new line from the battery, or feed off of the lighter socket and several other places. If you are going to use a relay, you can tap into anything you want.
Old Aug 13, 2010 | 12:28 AM
iMakana's Avatar
iMakana
The constant wire runs a low voltage signal regardless if the trucks on or not. Will it drain the battery if I run the wire from the battery?
