05 trailer plug constant hot wire
Old Jan 1, 2006 | 11:45 PM
jetact's Avatar
jetact
i have an 2005 with the tow pakage and intergrated brake control. I would like to make to charging wire on the plug to be hot at alll times(with the key off). I have a enclosed 26' snowmobile trailer which has light inside of it and I would like to be able to run them without havign to turn the key on. Anyone know the best way to complete this.
Old Jan 2, 2006 | 08:12 AM
FrankLee's Avatar
FrankLee
Two options:
1. Run a wire from the battery to the 7-pin connector on the bumper. Snip the factory circuit and connect your new wire.
2. Add a battery on the trailer and hook it up to the trailer plug. The truck will keep it charged, you can use lights when trailer is unhitched, and it never hurts to have a spare battery when you are out in the sticks.
Old Jan 2, 2006 | 08:22 AM
rljett's Avatar
rljett
Question on option 2...
How would the hookup go? Factory wire through plug into trailer, snip existing accessory wire and connect to the (+) terminal of battery? And then attach the accessories to the (+) terminal also? And then bring the (-) terminal back to the common on the plug? This would put the battery in parallel right and not double the voltage, just the amperage?
Thanks in advance.
Old Jan 2, 2006 | 09:25 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
I haven't looked at the wiring diagrams, but I believe there is a relay under the hood that turns the charging wire on with the ignition. Should be an easy task to pull the relay and just jumper the two terminals together -( + 12 to charge wire). Look at the diagram on the relay to figure out which terminals. Or take a dead relay and open it up, cut out the coil, and just solder a wire across the remaining two terminals, and plug it in .......Just check the wiring diagram to be sure ......BUT, if you forget to turn the light off you will have a dead battery - the main reason it comes on with ignition in the first place.
Old Jan 2, 2006 | 11:00 AM
Toyman's Avatar
Toyman
rljet.....You would want the ground wire to go directly to the trailer frame, there may be an existing ground bolt you can use. The positive from the 12v feed wire to the battery, and the wire to the switch for the lights inside from there, be sure to put a fuse in line.
Toyman
Old Jan 2, 2006 | 11:37 AM
rljett's Avatar
rljett
Toyman...thanks! I'm assuming something like a 15 amp fuse between the (+) terminal and the accessories?
Old Jan 2, 2006 | 11:57 AM
jetact's Avatar
jetact
Thanks to everyone. I think I going to try and figure out if I can get rid of the relay. If not it is on to running a separte wire.
Old Jan 2, 2006 | 11:40 PM
Cowboy Brett's Avatar
Cowboy Brett
If you've got the factory plug on there, it should have a little diagram on it that tells you which terminal is what, and from there you should be able to get the wire.
Unless something has changed drastically between 04 and 05, I woulu point you in the direction of the orange wire being your 12V + source from the truck.
As another idea, you might be able to simply remove the battery charge relay in your power distribution box and put a jumper across there. If you do that, though, I would advise that you make sure that the circuit will still have a fuse on it (if not, add one) and be sure that the jumper is a heavy enough wire gauge to handle the amperage you plan on sending to that trailer. The factory wiring is only good to 20A, I believe. I can't remember the wire gauge. 12 or 14 probably.
Personally, I like the second battery route. It doesn't require any messing around with Ford's wiring.
Old Jan 2, 2006 | 11:49 PM
ford390gashog's Avatar
ford390gashog
the easy way would to just add a battery to the trailer.
Old Jan 3, 2006 | 01:33 AM
cangim's Avatar
cangim
For what you are wanting, go with the jumper option, pull the relay, probably 4" of wire, 12 ga. crimp some large spades (male) on each end, plug it into the appropriate slots where the relay was. The output will still be fused by factory 30A fuse in the fuse box. As stated before, this will allow the possibility of dead batteries from the trailer but is by far the easiest way. I went the route of adding a battery, but that is more involved than putting in a jumper.
Old Jan 3, 2006 | 08:27 AM
Toyman's Avatar
Toyman
rljett
you should be fine with a fifteen amp fuse.
toyman
Old Jan 3, 2006 | 11:06 AM
n9emz's Avatar
n9emz
x2
Properly solving a problem is doing so in a way that doesn't create potential for others. Newer truck circuitry is very sensitive, there's a lot going on in the CJB, and it's an expensive item to replace (backside is non-serviceable). Think long and hard before modifying your wiring/circuitry.
Old Jan 3, 2006 | 01:06 PM
cangim's Avatar
cangim
Originally Posted by Toyman
rljett
toyman
Yes, I agree 15A would be just fine, my truck list a 30A fuse for the battery charge line, I would imagine his list the same. I have added all kinds of stuff to my charge line. But I agree, think it through before you modify any of the wiring on your truck.
Stroker16
Jul 25, 2014 04:54 AM
joegebff
Apr 29, 2011 10:55 PM
Coccyx
Jul 10, 2010 12:45 PM
fishman69
Aug 4, 2004 09:18 PM
elkstone
Electrical Systems/Wiring
Oct 22, 2003 05:22 PM
