Code 1293 and Forscan
Old May 16, 2021 | 07:39 PM
Swaybar1's Avatar
Swaybar1
Hello all
I have a beautiful 2003 Ford Exc 4x4 7.3L that is under the weather. One of the main problems, probably, is the previous owner attached it to his boat as a yard ornament and rarely started or moved it. We have had it for over a year now and I have replaced and done as much maintenance as I can get to. Recently the Queen left but pulled back in to get her phone....and as she was driving back it it started to run very rough. I use Forscan and an EX scan tool and came up with 1293.
I changed the v/c gasket and re-scanned after it still ran rough on start up(but at least it would start easily).
Has anyone had a similar issue and if so what was your final solution?
Running Forscan and get code 1293?
I am at a loss as it was giving no issues prior, no warning for anything but when I pulled the v/c the plug did appear to be separated so I thought that might be the solution.
File Type: mov
Old May 17, 2021 | 06:46 AM
projectSHO89's Avatar
projectSHO89
There are about 150 previous threads with your DTC, either with or without the letter "P" prefix. There's probably nothing new under the sun that hasn't been covered before so plugging that fault code, in both its variations, into the search tool will likely lead you to plenty of discussions to get you started
sandyc
6.7L Power Stroke Diesel
May 30, 2018 12:21 PM
whitelx50
Jun 22, 2017 01:03 PM
t-bone31
Feb 16, 2015 02:55 PM
KHADIJE22
6.4L Power Stroke Diesel
Oct 23, 2011 08:40 AM
bwalshma
Mar 29, 2005 01:02 PM
