engine problems
Old Oct 29, 2003 | 01:37 PM
35l911's Avatar
35l911
Exclamation engine problems
what are the signs of a dieing engine because i have moisture around the head gasket and the oil has a white foam to it and there are metal shavings in it and it has a tosted almond smell to it and i was going to take it to the dealer to get the oil changed but this is what i noticed its been about 4000 miles since the last oil change
Old Oct 29, 2003 | 08:19 PM
locknkey's Avatar
locknkey
Sounds like a leaky head gasket, warped head from running too hot will do that...time for a new engine.
Old Oct 29, 2003 | 08:50 PM
35l911's Avatar
35l911
the engine never ran hot since i'v e owned it just started doing this when i checked the oil level i noteced it for the first time
Old Oct 29, 2003 | 09:20 PM
locknkey's Avatar
locknkey
Heads usually don't go bad by themselves, bad gaskets...nah, if the engine was running before, the temp gage might not had detected the increase in temp, thus it didn't show because of oil or loose connections...if the engine head gasket didn't over heat, there is one other possiblity...a cylinder wall crack, over time the crack gets bigger till you realize you're making shush in the engine. I doubt that condensation would let that much mositure in to make your oil milky white, and the other description about the metal shaving could be a cracked cylinder wall...time for a new engine...
Old Oct 30, 2003 | 02:40 PM
35l911's Avatar
35l911
the engine is ok just got the word from ford that the milky white oil is from condisation and the metal flakes i saw wasn't metal it was from debree from the last oil change they didn't clean the engine out the last time
im sooo happy my engine dos't need to be changed
Old Oct 30, 2003 | 09:10 PM
locknkey's Avatar
locknkey
They never clean the engine out....good luck.
Old Oct 31, 2003 | 06:54 AM
83 F350's Avatar
83 F350
Do a compression test and see if they're all fairly close.
Old Oct 31, 2003 | 05:33 PM
UglyTruck's Avatar
UglyTruck
From what I just read I would have to go with the head gasket or cracked head idea....I thing that your garage is feeding you a line.....
Unless you are running a briggs and stratton 3 horse engine it is pretty hard to get enough condensation in the oil to make a milkshake... the fact that it is milky suggests that it is antifreze...not water......
I hope that I am wrong,,,,good luck
Old Oct 31, 2003 | 06:48 PM
bigreave's Avatar
bigreave
My 85 shows a little foam at the bootom of the dipstick when the oil gets low but no shavings and mine's compresson is real good. But when you chnge the oil no water in the drain pan. So i just drive till you kill it compltely.
Old Oct 31, 2003 | 09:24 PM
drosebrugh's Avatar
drosebrugh
Give it a few more miles and change your oil again. That will inform you on whether your garage was feeding you a line or not...
Old Oct 31, 2003 | 09:26 PM
drosebrugh's Avatar
drosebrugh
...from there start shopping, have you considered upgrading to a 351W.... yeah baby
Old Nov 1, 2003 | 08:18 PM
35l911's Avatar
35l911
the oil was changed and there is no more milkshake conditions or shavings in the oil the engine oil has been clean for 3 days now but ford dose tell me the carb is bad and never buy aftermarket rebuilds(its the 3rd one)
