Anderson hitch issue?
Old Jun 23, 2021 | 06:53 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe that all of the AUH's that have failed were of the aluminum variety. At least all of the ones that have been pictured on FTE have been. The steel ones are rated at 26k IIRC.
Old Jul 4, 2021 | 08:02 AM
hookd's Avatar
hookd
Anderson had instructions to drill out the bottom frame for the pucks so you could use the safety chain connectors. I did it and it worked but I really didn't like all the up and down with landing gear so I snagged a b&w companion that uses the puck system. Hooking up is easier, the hitch isn't that heavy in 2 pieces, and you don't have to worry about the warranty drama.
Old Jul 5, 2021 | 08:54 PM
2five7's Avatar
2five7
The only reason Lippert has approved the Reese goosebox is because they have a financial agreement with each other, has nothing to do with strength or safety.
I hear lots of internet rumors about Andersen's failing, but nobody ever has any first hand experience or pics to prove it (besides the one we've all seen)
If you don't like the aluminum Andersen, take a look at the Pullrite 2600, similar concept but steel construction, and not very heavy at only 52 lbs.
Old Jul 5, 2021 | 11:14 PM
ATC_F350's Avatar
ATC_F350
I don't doubt the financial side, but a Goose Box is not a weak hitch and as safe as they come.
Old Jul 6, 2021 | 07:01 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
In my humble opinion, I don't believe he was insinuating the Goose Box was weak, he was stating his thoughts on the AUH.
Old Jul 6, 2021 | 10:33 AM
2five7's Avatar
2five7
Correct. The goosebox is an excellent design, as is the Andersen.
Old Jul 6, 2021 | 05:57 PM
mecdac's Avatar
mecdac
I'm leaning toward the Reese Goose Box after hours of tedious research.
Nothing against the Andersen or Pull Rite systems.
Old Jul 7, 2021 | 10:42 AM
karlsdash's Avatar
karlsdash
gen-y makes a good hitch replacement as well. https://genyhitch.com/product-catego...-torsion-flex/
Nothing wrong with the reese goosebox, and i dont get paid by gen-y (unfortunately) but i like there stuff and it seems to be a great product. Actually slightly cheaper to get the gen-y, i bought it since it was a local option. Reese goosebox would have come freight and taken a month.
Old Jul 7, 2021 | 11:46 AM
mecdac's Avatar
mecdac
Not possible...
Mrs Forrest Gump will not be a part of my set-up.
Old Jul 7, 2021 | 01:32 PM
ATC_F350's Avatar
ATC_F350
One advantage to the GooseBox is that it is 2.7" longer than the Gen-Y, so you get more offset built into the hitch.
Old Jul 7, 2021 | 05:24 PM
Sous's Avatar
Sous
FTE Emeritus
You have to go with the best choice for your application and what your gut is telling you.
alaskapilot95
51
Jun 24, 2019 11:05 AM
Big Red Dumptruck
Apr 2, 2013 12:46 AM
6.9 diesel nut
13
Oct 31, 2012 08:32 AM
j tate
May 12, 2011 06:44 AM
matt_97xl
1997 - 2003 F150
Jun 29, 2004 06:19 PM
