Fuel pump questions maybe?
Old May 13, 2021 | 06:54 AM
pineapple_tree's Avatar
pineapple_tree
Unhappy Fuel pump questions maybe?
I just want to say, I have no experience with working with diesels, I’ve only worked on gas-powered engines, but then again I learn as I go.
Okay, so here’s the problem. I’m in the process of looking for a good diesel work truck, and I found one that was a 92 F350, with the 7.3l idi, manual tranny. The guy is selling it because of a fuel pump problem and doesn’t have the time to work on it. Problem is, he was messing with the fuel pump, and from what I can gather, was trying to turn the fuel pump “up”, and ended up making it not start. Now, from my understanding, is that the fuel pump is mechanical, and operates off of the camshaft lobe, which is done through a long arm that builds fuel pressure so it can be distributed. Could he of turned the fuel pump up too much to where it flooded the engine? Or something worse? Is it fixable, or even worth fixing? Is it possible that he only cranked it once and because he drained the fuel out, it didn't start?
I should also note I haven’t bought it yet, but rather came here to see my options to see if it’s worth fixing.
Old May 13, 2021 | 07:07 AM
Olds64's Avatar
Olds64
Be wary. "Turning up" the fuel pump references a fuel delivery screw on the side of the injection pump. This is what you can adjust if you want to "roll coal." The problem is that if you start delivering more fuel to the engine your temps will rise and you could cause the engine to self destruct. Does the truck have a pyrometer?
The mechanical lift pump is on the front of the engine near the bottom. As you said, a lever arm rides on an eccentric that causes the fuel pump to actuate.
Old May 13, 2021 | 07:18 AM
pineapple_tree
From what I can gather from him, he tried to turn it up to try and get something out of it, but it never started after he messed with it. I think he didn't crank it enough to get fuel back into the injection pump because he took that fuel bowl off. It never started after he tried to "mess with the pump", so is there a chance that once I buy it, I can readjust the screw and then crank it over multiple times and hope for the best? Or is there a chance he really ****ed it up?
Old May 13, 2021 | 07:55 AM
pineapple_tree
Just got some more info, it seems he broke the screw on the injector pump...
Is that an easy fix, or do I have to replace the injector pump?
Old May 13, 2021 | 08:14 AM
Olds64's Avatar
Olds64
RUN!
If the fuel delivery screw is broken you would have to disassemble the injection pump to replace it and return it to 0. Unfortunately, you need precision measuring tools to set the delivery screw to the OE position. When the IP is "turned up" you rotate it a flat or two (60*-120*). A pyrometer lets you know if your exhaust temps get too high.
If he hadn't messed with the IP it might be a worthwhile project. When I first bought my Bullnose I pulled the ring on the OE water separator and caused some major air intrusion. It took me a week or two to get it running again.
Old May 14, 2021 | 09:33 AM
tecgod13's Avatar
tecgod13
I will counter that depending on what he is asking, and how cheaply you can find a working injection pump, it may be worth it. As Olds64 said you likely will not be able to use the existing pump as is.
If the truck is in good shape it might be worth your while. Especially if you are not afraid to do some work yourself, and have a decent junkyard nearby where you might be able to find a pump for cheap. However, if you don't have access to timing tools, and haven't worked with a diesel before, this may be out of your realm.
Where are you located? and what is the guy asking?
Old May 16, 2021 | 05:00 PM
Prototypemech's Avatar
Prototypemech
It also depends on which 'screw' he broke. There is a cover plate on the side of the injection pump that allows access to the fuel screw. That cover plate is held on with 2 screws. If he broke one if those, fuel will pour out of the IP and itll never start.
In my opinion, you cant break the fuel screw. Its a hex-drive and its in a very awkward spot. You'll round off your allen wrench or the fuel screw before you break the fuel screw.
Old Nov 21, 2023 | 07:15 AM
timrothschild1's Avatar
timrothschild1
Am I missing something here? Title says 94.5 to 97 powerstroke
Old Nov 21, 2023 | 07:21 AM
timrothschild1
Broke fuel pump tapper
I accidentally dropped a tappet on my first fuel pump replace. 1995 powerstroke. This was long before internet help. Did not know to hand crank motor till pump popped up. Any way it went down and was no way to drill. Wile trying to fish it out it just fell to oil pan. I put the old tappet in new pump and it stayed there until i change pan 200k miles later. Good luck
Old Nov 21, 2023 | 10:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
completely different animal. about the only thing the same with IDI and powerstroke is the engine size
clinkfield
Aug 23, 2018 07:40 PM
rondawgg1118
Feb 11, 2007 09:30 PM
krzyk26
Mar 29, 2005 05:49 PM
