Hard warm start
Old May 12, 2021 | 11:21 PM
Alfred Pennyworth's Avatar
Alfred Pennyworth
Hard warm start
Hello! I’m new to the site and need your help. I recently purchased a 1990 F250 5.8 351 Windsor that was a farm truck. I got it for $300 and it ran and drive and just needed some love to make it the awesome truck I have always wanted. I have replaced almost everything and I am still running into a warm hard start issue.
here is a list of everything I have replaced:
-Alternator
-Starter
-Ignition coil
-Battery
-Smog pump
-Battery terminals
-Thermostat
-Temp sensor
-Air intake sensor
-Checked and cleaned ground going to battery
-Fuel regulator
-checked injectors and none leaked
i pulled off the distributor cap and cleaned the contacts and it still having a hard warm start. I don’t know where to turn and know there has to be someone smarter than me or has ran into this issue themselves.
Old May 13, 2021 | 02:11 PM
jas88's Avatar
jas88
Please explain "hard warm start". Does it crank slowly? Or you have to crank a long time before it starts?
Old May 13, 2021 | 04:15 PM
Alfred Pennyworth
you can hear the starter engage but it won’t crank at all. The lights dim in the dash and battery drops to 9-10 volts on the gauge. It does not turn over at all. After about 20 minutes of letting the engine cool down it fires right up.
Old May 13, 2021 | 04:37 PM
Mikulh's Avatar
Mikulh
Hi Alfred. Please give my regards to Bruce.
I had this happen once when my starter cable insulation had deteriorated and was grounding to the frame. It was causing a dead short whenever I tried to engage the starter.
Once I figured it out it was fixed very easily by replacing the cable.
Vinford
Oct 19, 2019 12:43 PM
loganddanish
May 24, 2017 08:37 AM
Dilligas
15
Feb 4, 2008 07:41 AM
weekendwarriorfsw32
21
Dec 20, 2007 09:44 AM
TimSmi
19
Sep 30, 2003 02:08 AM
