92 Hard start
Old Oct 16, 2019 | 08:45 PM
Vinford's Avatar
Vinford
92 Hard start
1992 F-250 with a 351
Starts like a Dodge?
Grinds over lots before starting , its worse when cold.
Almost wont start sometimes.
Where to start?
Old Oct 16, 2019 | 09:38 PM
torq'ta 5 8's Avatar
torq'ta 5 8
how old is battery, my alternator just gave up, above 2000 rpm charging fine(14.21 volts) at idle less than 12.38 volts, then this cool spell here battery started dragging, (4yr old), so before it gets cooler, I went ahead and got battery also
Old Oct 17, 2019 | 09:18 AM
Vinford's Avatar
Vinford
Its not the battery , it would never start if it were a bad battery , it turns over for 5 mins before it starts.
Old Oct 17, 2019 | 09:41 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Best guess would be a marginal TFI and/or PIP. Are both still the factory original parts?
Old Oct 18, 2019 | 09:37 AM
Vinford's Avatar
Vinford
What does that stand for please?
Old Oct 18, 2019 | 07:00 PM
torq'ta 5 8
PIP is in distributor
TFI=ICM(sometimes called)
Old Oct 18, 2019 | 10:03 PM
Vinford's Avatar
Vinford
I looked for ICM , even found a picture but cannot find it on the truck>
Old Oct 19, 2019 | 12:43 PM
My4Fordtrucks's Avatar
My4Fordtrucks
TFI: “thick film ignition, or thick film integrated ignition.”
Depending on the model year it is located on the side of the distributor or on the fender by the driver’s side hood hinge
PIP: “The PIP signal is just Ford's name for the crankshaft position sensor signal. Now, in case you're wondering, the PIP sensor is located inside the distributor.”
JumpinJoe
Apr 17, 2009 06:22 PM
Fordnazcar
Jan 14, 2009 06:10 PM
nailer
Modular V10 (6.8l)
17
Jan 7, 2006 11:45 AM
