DEF system
Old May 12, 2021 | 02:05 PM
dmertes's Avatar
dmertes
DEF system
I recently had the 18M01 recall done on my 2011. Does anyone know if it is common to put a new def pump in after this recall? Second question is now that the recall is done will I get the low def mileage warnings back in the center information screen? 800 mi, 400mi to empty and so on I was only getting a CEL when the def got low before the recall work was done. Thank You.
Old May 12, 2021 | 05:59 PM
Just Strokin's Avatar
Just Strokin
The DEF pump possibly can be replaced. It has to be removed to change the tank heater.
What dash/instrument cluster do you have? Does it have the center display screen or single line display?
Old May 12, 2021 | 06:58 PM
kper05's Avatar
kper05
Properly working, the two line display on a 2011 will begin the notifications at 800 MTE and then every time at startup. If yours doesn't after repair, something else is wrong.
Old May 12, 2021 | 09:27 PM
dmertes's Avatar
dmertes
I have the center display screen. It used to give me the miles to empty periodically for the def just wondering if it will work again after the reacall?
Old May 13, 2021 | 05:22 AM
senix's Avatar
senix
it should work as originally from the factory. The tech will be in the pcm for the procedure if you are having it done.
Old May 14, 2021 | 05:51 AM
kper05's Avatar
kper05
The 800 MTE on mine was not affected by the DEF heater failure, I drove with the problem I think two months. Mention this issue to the SM so they can investigate.
Jimster512
Jun 29, 2020 10:00 AM
PWH42
May 11, 2020 10:00 AM
Burnetaggie99
6.7L Power Stroke Diesel
Oct 9, 2012 03:03 PM
2horses
Oct 19, 2011 04:03 PM
mongoo
2009 - 2014 F150
19
Mar 4, 2011 03:44 PM
