EGR Lines
Old 05-12-2021, 10:03 AM
Nathan Greer's Avatar
Nathan Greer
Nathan Greer is offline
EGR Lines
Those hard plastic lines on my truck need replacing. I can use small vacuum hoses to replace those right? Or does someone know where to get some?
EGR Lines
Old 05-12-2021, 03:21 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,726 Likes on 1,396 Posts
Rubber vacuum lines will work fine for that.
Old 05-12-2021, 06:37 PM
sdelivery's Avatar
sdelivery
sdelivery is offline
A hydraulics store like a "parker" store sells many varieties of plastic tubing as well as rubber
Old 05-12-2021, 08:17 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
I been looking for either colored striped vacuum hose or colored plastic tubing myself for when I gut my original vacuum system off my '82 and replace it with all new minus most emission systems.
Couldnt find much outside of some people recommending MSC Direct as a source where they got their plastic tubing from.
Plastic, Rubber & Synthetic Tube - MSC Industrial Supply (mscdirect.com)
Inline tube has some painted striped hoses but a lot of what they got is labeled as "Chevrolet" and it doesnt matter as a engine wont know if the stripe is GM based or Ford based when it comes to vacuum hoses.
Silicone is another option, I looked at it myself as well as it has a higher temp range than standard rubber, it isnt attacked by UV and is supposed to last three times as long as traditional rubber hose. I personally dont know as I want to color code my vacuum system and not sure how solid colored silicone vacuum hose would look.
Old 05-13-2021, 03:11 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,172 Likes on 1,844 Posts
It just hit me I wonder if the plastic lines on my work truck shifter, 18 wheel, as it uses air for low range (1-5) and high range (6-10)?
There might be other lines on the truck that I have not looked that closely at?
If you have a good truck stop that has shift handle extensions they would also carry the plastic line.
I will look over the truck tomorrow and if we get gas at the stations, 70% in NC are out of gas because of the pipe line issue, I will see if the truck stop a few towns over has the line and what side it is.
Dave ----
BennyLumpkin
04-11-2013 03:30 AM
morse
08-18-2012 08:18 AM
mpavlyik
1978 - 1996 Big Bronco
01-30-2008 10:59 PM
stevorino
08-23-2004 11:35 AM
Quick Reply: EGR Lines
