Vacuum Lines....
Old Apr 10, 2013 | 08:08 PM
BennyLumpkin's Avatar
BennyLumpkin
Vacuum Lines....
So while doing some tune up work and changing my EGR I found how truly brittle those plastic vacuum lines really are. What route of replacment have you used? Rubber? Are there direct replacements? I patched them but its temporary and not perfect. This is on a 95 F350 460efi. Its the lines from the vacuum canister to the EGR sensors and EGR.
Old Apr 10, 2013 | 09:02 PM
951504x4's Avatar
951504x4
Did the exact same thing on my 95 150. I went to the local Autozone/ Advanced w/e and they had sections of replacement lines for around $5-8. Ive also gotten some heat shrink patches (not sure what they are called) and used those. Both have worked well.
Old Apr 10, 2013 | 09:06 PM
BennyLumpkin
I did the shrink wrap but I still have a leak.... think its hidden by the split loom it's all wrapped in. Its driving me nuts because I have a slight miss and an EGR code....says its not opening but I just replaced it.
Old Apr 10, 2013 | 09:15 PM
UncleCracker302's Avatar
UncleCracker302
I actually just read on a bronco forum today about someone who used all silicone tubing rather than rubber or plastic. Just a thought...
Old Apr 11, 2013 | 03:30 AM
Bob Gervais's Avatar
Bob Gervais
I replaced all of mine with standard rubber vacuum line. Haven't had an issue with any of it.
BjpouserXLT
Oct 31, 2018 01:16 PM
john544
1997 - 2003 F150
Oct 20, 2016 11:44 PM
gbrewer
Nov 4, 2010 11:48 PM
mpavlyik
1978 - 1996 Big Bronco
Jan 30, 2008 10:59 PM
eigenvector
1983 - 2012 Ranger & B-Series
Sep 5, 2006 07:49 PM
