1978 - 1996 Big Bronco
hard plastic vacuum lines
Old Jan 30, 2008 | 03:58 PM
mpavlyik's Avatar
mpavlyik
okay. I have a 1989 Bronco 351 C6. On the drivers side of the engine, right next to where the coil mounts, you have some hard plastic vacuum lines, I believe one is green, one is yellow, one is black, and I'm not sure about the others. They route behind the engine, and a couple go to the vacuum canister, one goes to the EGR valve, etc. Anyways, one of mine (the yellow one) is cracked in half, and I believe the one going to the EGR valve is leaking. I was just going to buy some soft rubber vac lines and replace them, but the one end is molded, it appears. Does anyone have a work around on how to repair these or do you know where I can get new ones. I figure any thing from the junkyard would be cracked, and to be honest, if I don't have to go to a dealership, I would rather not.
Thank you in advance for any help you can give me,
Mike
Old Jan 30, 2008 | 04:18 PM
Kemicalburns's Avatar
Kemicalburns
just run rubber lines thats what i had done awhile back
Old Jan 30, 2008 | 04:25 PM
rollerstud98's Avatar
rollerstud98
Those years had EGR? Did they do away with it afterwards or was it still on there right up to 96?
Old Jan 30, 2008 | 10:59 PM
Surge08's Avatar
Surge08
You can run rubber lines, Color just makes it easier to trace.
HoustonDave
13
Jan 9, 2018 06:30 PM
1993 ford
Jun 10, 2017 03:55 AM
bobbydee
1997 - 2003 F150
Oct 21, 2016 02:39 PM
Ralph_D
Sep 14, 2006 06:15 PM
sholliday
Jul 8, 2005 08:18 AM
