Vacuum pump operation
Old May 10, 2021 | 09:00 AM
JimmyRoach's Avatar
JimmyRoach
2004 F350 SD 6.0, Once the vacuum build up to control the air flow selection door, is the vacuum supposed to remain as a vacuum, or will bleed out after X hours when the truck is parked ?
I replaced the vacuum reservoir tank and vacuum pump, and now have hot air coming out of the panel vents, how do I test the temperature blend door operation. what is the resistance value for the temperature control potentiometer between pin 1 & 3 the full resistance value and the variance between pin 1 & 2, and 2 & 3. Also is there a way to test the blend door actuator motor?,
Old May 10, 2021 | 10:56 AM
Yahiko's Avatar
Yahiko
I think the testing info your looking for is in here somewhere.
Old May 10, 2021 | 11:36 AM
JimmyRoach's Avatar
JimmyRoach
thank you so very much
Old May 10, 2021 | 01:46 PM
FiveOJester's Avatar
FiveOJester
The vacuum system will typically bleed down overnight as my pump always runs when I first start the truck in the morning but it should build vacuum and then shutoff. When I change positions on the HVAC **** the pump will usually come on for a short time to rebuild vacuum.
pounder90
1997 - 2003 F150
Nov 5, 2018 06:51 PM
diesel_dan
Oct 9, 2018 05:26 PM
SmackDaddy
Nov 23, 2016 11:10 AM
hanklin
Jul 26, 2015 11:26 AM
FireControlman
Jun 7, 2010 01:18 AM
